35mm–70mm f/2.8 Vario-Elmarit-R ASPH
- Order no. - 11275
- Production era - 1998-2002 < 1,775 lenses (Overgaard, Westlicht & Schouten all say only 300 lenses produced (Rahn lists 155) - surprising with 1,775 assigned)
- Number of lenses /groups - 11 / 9
- F stop range - f/2.8 - f/22
- Closest focusing distance - 70 cm / 2.30 ft
- Smallest object field - Macro setting 67 x 101 mm /1:2.8
- Angle of view diagonal - 64 - 34 degrees
- Filter type - E77
- Dimensions (length x diameter) - 133 x 88 mm /5.24 x 3.46 in
- Weight - 1050 g /2.31 lb
- Inscription - LEICA VARIO-ELMARIT-R 1:2.8/35-70 ASPH. E77 3XXXXXX
- Leica Tech Data - 35mm–70mm f/2.8 Vario-Elmarit-R ASPH.pdf - courtesy Summilux.net
- On the street - €EU 5,520 in 2006; 4,800 in 2011
35mm–70mm f/2.8 Vario-Elmarit-R ASPH Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf| SN Start | SN End | Product | Year | Total |
| 3654696 | 3654715 | 35mm–70mm f/2.8 Vario-Elmarit-R | 1994 | 20 |
| 3812110 | 3812124 | 35mm–70mm f/2.8 Vario-Elmar-R | 1997 | 15 |
| 3839000 | 3839999 | 35mm–70mm f/2.8 Vario-Elmar-R | 1998 | 1000 |
| 3890957 | 3890996 | 35mm–70mm f/2.8 Vario-Elmar-R | 2000 | 40 |
| 3894351 | 3895050 | 35mm–70mm f/2.8 Vario-Elmar-R | 2000 | 700 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1994-2000 | 1,775 |
