135mm f/2.8 Elmarit-M II
Revision as of 15:52, 14 October 2014 by Tdavis (talk | contribs)
  • Leica Order No. - 11829 . LLC - 184
  • Production era - 1964-1973 < 10,301 lenses
  • Type - As camera lens + optical cell unscrews for use with focusing adapter 16464 on Visoflex
  • Number of lenses /groups - 5 /3
  • F stop range - f/2.8-f/32
  • Closest focusing distance - 1.5 m /4.92 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 18 degrees
  • Filter type - E55 - A63.7
  • Accessories - Filter-ring: 14161
  • Weight - 730 g /1.61 lb
  • Inscription - ELMARIT-M 1:2.8/135 LEITZ CANADA 1XXXXXX
  • Designer - Walter Mandler
  • Tech Data - Erwin Puts (2002) Leica M-Lenses.pdf - pgs. 72 - 75
135mm f/2.8 Elmarit-M II Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf
* Lens nos. 2064146, 2064302, 2064679, 2326149 are Elmarit-M 2.8/135mm (11829)
2063501 *2065500 *35mm f/2.8 Elmarit-R* 1964 [2000]
2151551 2152550 135mm f/2.8 Elmarit 1965 1000
2223201 2224000 135mm f/2.8 Elmarit 1967 800
2258901 2259900 135mm f/2.8 Elmarit 1968 1000
2288951 2289950 135mm f/2.8 Elmarit 1968 1000
2324301 2326300 135mm f/2.8 Elmarit 1969 2000
2326301* 2327800 50mm f/2.8 Elmar* 1969 [1500]
2424201 2425700 135mm f/2.8 Elmarit 1970 1500
2466501 2468500 135mm f/2.8 Elmarit 1970 2000
2655901 2656900 135mm f/2.8 Elmarit-M 1973 1000
2681801 2682800 135mm f/2.8 Elmarit-M 1974 1000
TOTAL ASSIGNED SERIAL NUMBERS 1964-1976 10,301
Lens superseded by 135mm f/2.8 Elmarit-M III
