M Monochrom
- Production era - Aug 2012-current
- Code nos. - 10760-black, 10797-SAE (Silver /brown leather Anniversary Edition of 25) - 10794 100yr set (SS/M Monochrom + M-A 127 + 3 lenses)
- Camera type - Compact digital rangefinder system camera with a dedicated black-and -white image sensor [JPG toning options: Sepia, Cold and Selenium- Weak or Strong] -js
- Image sensor - CCD active area approx. 23.9 x 35.8 mm, 5212 x 3468 pixels (18 megapixels). Infrared blocking filter for invisible light with wavelengths longer than 700 nm, no low-pass filter (made by Jenoptik).
- File type - RAW, JPG, RAW + JPG
- Color spaces - sRGB hardwired
- Exposure metering - Exposure metering through the lens (TTL), center-weighted at working aperture - Center-weighted TTL-metering for flash with system-compatible SCA-3000/2 standard flash units
- Flash exposure control
- Flash metering - Control by center-weighted, TTL pre-flash metering (with SCA-3501/3502 adapters or SCA-3000 standard
- Viewfinder
- Long-base rangefinder - Bright rectangular spot (RF spot) with coincident and superimposed fields in the center of the *viewfinder image
- Read-out
- Monitor - 2.5″ monitor display (color TFT-LCD) with 230,000 pixels [and brightness adjustment]
- Shutter /shutter release
- Camera body
- Manuals & brochures
- Current Firmware Version - always download Manufacturer's latest firmware
- Bugfix to improve stability in “Discreet”-Mode
- Linguistic improvements in French, Italian
- Improved stability when the camera is connected to USB
Current Digital-M Camera Accessories
- Close-up Accessories
- 11 670
- MACRO-ADAPTER-M
- 11 670
- Film Advance
- 14 408 - Motor-M
- 14 450 - Leicavit-M - Black chrome-plated
- Flash Units
- Viewfinder Accessories
- 12023 - LEICA VIEWFINDER M - 18 mm / silver-chrome
- 12024 - LEICA VIEWFINDER M - 21 mm / black paint finish
- 12025 - LEICA VIEWFINDER M - 21 mm / silver-chrome
- 12026 - LEICA VIEWFINDER M - 24 mm / black paint finish
- 12027 - LEICA VIEWFINDER M - 24 mm / silver-chrome
- 12531 - ANGLEFINDER M
- Cases, Straps and Covers
- 14312 - Replacement carrying strap
- 14495 - Replacement camera bayonet cap
- à la Carte Carrying Straps - 14453, 14469, 14457, 14458, 14454, 14456, 14468, 14465, 14466, 14467
- 14 455 - Wide Carrying Strap
- Neoprene Case M - with short front part 14867 - with long front part 14868
- Tripod Accessories
- 14 110 - Ball Head
- Ergonomics
- 14 400 - HAND GRIP M9 - steel-gray paint
- Power Supply - see DIGITAL-M POWER SUPPLY
- Test Shots
- Videos
M Monochrom Serial Numbers
Serial numbers compiled from known M Monochrom cameras~ stolen camera, please report if found on sale
| -4341312 | 4349216- | M Monochrom | 2012 | 7,905+ ~4344776 |
| -4350688 | unknown- | M Monochrom (SAE) | 2013 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2012-2013 | unknown |
