VARIO-ELMAR-T 18-56 f/3.5-5.6 ASPH.
Revision as of 17:23, 5 December 2014 by Tdavis (talk | contribs) (→VARIO-ELMAR-T 18-56 f/3.5-5.6 ASPH. Serial Numbers)
- Product no. - 11080
- Production era - 2014-
- Lens Mount - Leica T stepper motor zoom
- Focal Length (35mm Equivalent) - 18 - 56 mm (27 - 84 mm)
- Maximum Aperture - f /3.5 - 5.6
- Minimum Aperture - f /16 [18?] adjustment using dial on camera, third values also available.
- Angle of View at 18 mm - approx. 75º, 62º, 41º (diagonal, horizontal, vertical)
- Angle of View at 56 mm - approx. 28º, 23º, 15º (diagonal, horizontal, vertical)
- Entrance pupil at 18 mm . -37.8 /19.9 mm (at infinity /at close up limit)
- Entrance pupil at 56 mm . -28 /49.7 mm (at infinity /at close up limit)
- Setting /Function - Electronically controlled, mode selectable using camera menu: Automatic (AF) or manual (M), in AF mode manual override possible at any times with setting dial.
- Minimum Focusing Distance - 11.8 in / 45 cm
- Magnification at 18 mm - approx. 312 x 207 mm /1 : 13.2
- Magnification at 56 mm - approx. 110 x 73 mm /1 : 7.5
- Lens Construction - 10 elements in 7 groups w/ 4 aspherical surfaces
- Filter Ring - E52 mm (non-rotating)
- Dimensions - length x diameter - 2.4 - 3.5 x 2.5 in /60 - 90 x 63 mm (w/o hood)
- Weight - 9 oz /256 g
- Barrel Material - Black anodized aluminum
- Accessories - Caps, Tulip hood 12425 included w/ lens purchase
- Leica Tech Data - VARIO-ELMAR-T 18-56 f/3.5-5.6 ASPH.pdf
- Leica data as of July 2014
- MSRP - £GB 1,250. $US 1,750 in 2014 w/ hood, caps and pouch
Serial numbers compiled from known VARIO-ELMAR-T 18-56 f/3.5-5.6 ASPH. lenses| SN Start | SN End | Product | Year | Total |
| -4332173 | 4337820- | VARIO-ELMAR-T 18-56 f/3.5-5.6 ASPH. | 2014 | 5,648+ |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2014-Current | unknown |
