100mm f/2.8 APO-Macro-Elmarit-R
Revision as of 17:44, 16 January 2015 by Tdavis (talk | contribs) (→100mm f/2.8 APO-Macro-Elmarit-R Serial Numbers)
- Order nos. - 11210 - 11352-ROM . LLC - 180
- Production era 1987-2009, 20,000+ lenses
- Lens mount - LEICA R quick-change bayonet for LEICA R3 to LEICA R9 with mechanical, and, for LEICA R8/R9, additional electronic exposure control
- Number of lenses/groups - 8 /6
- Focusing range - 45 cm / 17.7 in < ∞ , with ELPRO 1:2-1:1 30 cm / 11.8 in
- Aperture - f/2.8 - f/22 - Preset diaphragm with clickstops (including half values), Fully automatic diaphragm
- Smallest object field/Largest reproduction ratio - 48 x 72 mm, with ELPRO 1:2-1:1 22 x 35 mm / 1:2, with ELPRO 1:2-1:1 1.1:1
- Angle of view (diagonal, horizontal, vertical) - 24°, 20°, 13.7°
- Position of entrance pupil - 22 mm / 0.87 in (related to the first lens surface in light direction)
- Scales - Combined meter/feet-increments down to 0.7 m, engraved reproduction ratios from 1:5 to 1:2
- Filter mount/Lens hood - Internal thread for screw-in type filters E 60 / Built-in, telescopic
- Accessories - ELPRO 1:2-1:1; Rotating tripod collar: STA-1 14636
- Focal length - 100 mm / 3.9 in
- Length to bayonet flange - 104.5 mm / 4.1 in
- Largest diameter - 73 mm / 2.9 in
- Weight - 760 g / 1.7 lb
- Inscription - LEITZ APO-MACRO-ELMARIT-R 1:2.8/100 E 60 3XXXXXX
- Designer - Wolfgang Vollrath
- Leica Tech Data - 100mm f/2.8 APO-Macro-Elmarit-R.pdf
- On the street - $US 4,295 in 2008 - 1,300 (3-cam) - 1,600 (ROM) in 2010
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf| SN Start | SN End | Product | Year | Total |
| 3412891 | 3414890 | 100mm f/2.8 APO-Macro-Elmarit-R (11 210) | 1986 | 2000 |
| 3467571 | 3469570 | 100mm f/2.8 APO-Macro-Elmarit-R (11 210) | 1988 | 2000 |
| 3495901 | 3497900 | 100mm f/2.8 APO-Macro-Elmarit-R | 1989 | 2000 |
| 3509296 | 3510295 | 100mm f/2.8 APO-Macro-Elmarit-R | 1990 | 1000 |
| 3559368 | 3561367 | 100mm f/2.8 APO-Macro-Elmarit-R | 1991 | 2000 |
| 3593960 | 3594959 | 100mm f/2.8 APO-Macro-Elmarit-R | 1992 | 1000 |
| 3626901 | 3627900 | 100mm f/2.8 APO-Macro-Elmarit-R (11 352) | 1993 | 1000 |
| 3653696 | 3654695 | 100mm f/2.8 APO-Macro-Elmarit-R | 1994 | 1000 |
| 3696501 | 3697500 | 100mm f/2.8 APO-Macro-Elmarit-R | 1995 | 1000 |
| 3739701 | 3740700 | 100mm f/2.8 APO-Macro-Elmarit-R | 1996 | 1000 |
| 3762000 | 3762999 | 100mm f/2.8 APO-Macro-Elmarit-R (11 352) | 1996 | 1000 |
| 3792010 | 3793009 | 100mm f/2.8 APO-Macro-Elmarit-R (11 352) | 1997 | 1000 |
| 3830325 | 3831324 | 100mm f/2.8 APO-Macro-Elmarit-R | 1998 | 1000 |
| 3853600 | 3854599 | 100mm f/2.8 APO-Macro-Elmarit-R | 1998 | 1000 |
| 3889757 | 3890256 | 100mm f/2.8 APO-Macro-Elmarit-R | 2000 | 500 |
| 3901076 | 3901575 | 100mm f/2.8 APO-Macro-Elmarit-R | 2000 | 500 |
| 3938014 | 3938513 | 100mm f/2.8 APO-Macro-Elmarit-R | 2002 | 500 |
| 3959411 | 3959910 | 100mm f/2.8 APO-Macro-Elmarit-R | 2002 | 500 |
| unknown | unknown | 100mm f/2.8 APO-Macro-Elmarit-R | 2006-2009 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1986-2005 | 20,000 |
