50mm f/2 Summicron-R II
Revision as of 17:51, 16 January 2015 by Tdavis (talk | contribs) (→50mm f/2 Summicron-R II Serial Numbers)
- Order nos. - 11215-Leicaflex - 11216-R.only - 11345-ROM - 11217-R.only.Safari LLC - 123
- Production era 1976-2009, 99,736+ lenses
- Lens mount - LEICA R-bayonet for LEICA R3 to LEICA R9 with mechanical, and, for LEICA R8/R9, additional electronic exposure control
- Variants - Black, Safari green, R-only and 3-cam versions
- Number of lenses/groups - 6 / 4
- Focusing range - 0.5 m / 19.7 in < ∞
- Aperture range - f/2-f/16 - Preset diaphragm with clickstops (including half values), 6-blade fully automatic diaphragm
- Smallest object field/Largest reproduction ratio - 180 mm x 270 mm / 1:7.5
- Angle of view (diagonal, horizontal, vertical) - 47°, 40°, 27°
- Position of entrance pupil - 20.2 mm / 0.8 in (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-in type filters E 55 / Built-in, telescopic
- Accessories - ELPRO close focusing attachments type 1 and 2
- Focal length - 52.5 mm / 2.07 in
- Length to bayonet flange - 41 mm / 1.6 in
- Largest diameter - 66 mm / 2.6 in
- Weight - 290 g / 10.2 oz
- Inscriptions - LEICA SUMMICRON-R 1:2/50 E 55 3XXXXXX
LEITZ SUMMICRON-R 1:2/50 3XXXXXX
SUMMICRON-R 1:2/50 LEITZ CANADA 3XXXXXX
- Designers - Walter Mandler, Garry Edwards and Erich Wagner - June 1976
- Leica Tech Data - 50mm f/2 Summicron-R II.pdf
- On the street - $US 1,495 in 2008 - 600 (3-cam) - 790 (ROM) in 2010
- Puts-R courtesy of Mario Mazziol
- Mario Cavina
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf* Lens 2925638 is Summicron-R 11215 2/50mm R.only
** Lens 3082026 is Summicron-R 2/50mm R.only
^ Lens 2822922 is Summicron-R 2/50mm (2-cam)
| 2777651 | 2781650 | 50mm f/2 Summicron-R (11 215) | 1976 | 4000 |
| 2800401 | 2801400 | 50mm f/2 Summicron-R | 1976 | 1000 |
| 2816351 | 2816850 | 50mm f/2 Summicron-R | 1977 | 500 |
| 2822351^ | 2826350 | 50mm f/2 Summicron-M^ | 1978 | [4000] |
| 2834801 | 2838800 | 50mm f/2 Summicron-R (11 215) | 1977 | 4000 |
| 2862801 | 2866800 | 50mm f/2 Summicron-R | 1977 | 4000 |
| 2876201 | 2880200 | 50mm f/2 Summicron-R | 1977 | 4000 |
| 2889401 | 2893400 | 50mm f/2 Summicron-R (11 217) | 1978 | 4000 |
| 2922901* | 2926900 | 50mm f/2 Summicron-M* | 1978 | [4000] |
| 2941701 | 2945700 | 50mm f/2 Summicron-R | 1978 | 4000 |
| 2955501 | 2959500 | 50mm f/2 Summicron-R (11 217) | 1978 | 4000 |
| 2969251 | 2973250 | 50mm f/2 Summicron-R | 1979 | 4000 |
| 3009651 | 3013650 | 50mm f/2 Summicron-R | 1979 | 4000 |
| 3082001** | 3084000 | 50mm f/2 Summicron-M** | 1981 | [2000] |
| 3089001 | 3093000 | 50mm f/2 Summicron-R | 1981 | 4000 |
| 3096501 | 3098500 | 50mm f/2 Summicron-R | 1981 | 2000 |
| 3109001 | 3114000 | 50mm f/2 Summicron-R | 1981 | 5000 |
| 3161001 | 3163000 | 50mm f/2 Summicron-R | 1982 | 2000 |
| 3179201 | 3181200 | 50mm f/2 Summicron-R | 1982 | 2000 |
| 3203801 | 3205800 | 50mm f/2 Summicron-R | 1982 | 2000 |
| 3227301 | 3229300 | 50mm f/2 Summicron-R | 1982 | 2000 |
| 3233301 | 3234300 | 50mm f/2 Summicron-R | 1982 | 1000 |
| 3296201 | 3298200 | 50mm f/2 Summicron-R | 1984 | 2000 |
| 3302201 | 3306200 | 50mm f/2 Summicron-R | 1984 | 4000 |
| 3310701 | 3312700 | 50mm f/2 Summicron-R | 1984 | 2000 |
| 3322201 | 3323200 | 50mm f/2 Summicron-R | 1984 | 1000 |
| 3337201 | 3340200 | 50mm f/2 Summicron-R | 1984 | 3000 |
| 3351801 | 3353800 | 50mm f/2 Summicron-R | 1985 | 2000 |
| 3353801 | 3354800 | 50mm f/2 Summicron-R | 1985 | 1000 |
| 3379001 | 3380500 | 50mm f/2 Summicron-R | 1985 | 1500 |
| 3391801 | 3392800 | 50mm f/2 Summicron-R | 1986 | 1000 |
| 3411891 | 3412890 | 50mm f/2 Summicron-R (11 216) | 1986 | 1000 |
| 3437501 | 3438500 | 50mm f/2 Summicron-R | 1987 | 1000 |
| 3441001 | 3442400 | 50mm f/2 Summicron-R | 1987 | 1400 |
| 3479101 | 3480600 | 50mm f/2 Summicron-R | 1988 | 1500 |
| 3488791 | 3489190 | 50mm f/2 Summicron-R | 1989 | 400 |
| 3495301 | 3495660 | 50mm f/2 Summicron-R | 1989 | 360 |
| 3507846 | 3507995 | 50mm f/2 Summicron-R | 1990 | 150 |
| 3510796 | 3512795 | 50mm f/2 Summicron-R (11 215) | 1990 | 2000 |
| 3534768 | 3536767 | 50mm f/2 Summicron-R | 1990 | 2000 |
| 3567473 | 3569472 | 50mm f/2 Summicron-R | 1991 | 2000 |
| 3573133 | 3573133 | 50mm f/2 Summicron-R | 1991 | 1 |
| 3586940 | 3586959 | 50mm f/2 Summicron-R (11 217) | 1992 | 20 |
| 3617080 | 3617879 | 50mm f/2 Summicron-R | 1993 | 800 |
| 3619133 | 3620132 | 50mm f/2 Summicron-R | 1993 | 1000 |
| 3628901 | 3630000 | 50mm f/2 Summicron-R | 1993 | 1100 |
| 3632401 | 3633400 | 50mm f/2 Summicron-R | 1993 | 1000 |
| 3655826 | 3655830 | 50mm f/2 Summicron-R | 1994 | 5 |
| 3667031 | 3668030 | 50mm f/2 Summicron-R (11 216) | 1994 | 1000 |
| 3677031 | 3678030 | 50mm f/2 Summicron-R | 1995 | 1000 |
| 3735701 | 3736700 | 50mm f/2 Summicron-R | 1996 | 1000 |
| 3764800 | 3765799 | 50mm f/2 Summicron-R | 1996 | 1000 |
| 3784330 | 3785329 | 50mm f/2 Summicron-R | 1997 | 1000 |
| 3818625 | 3819624 | 50mm f/2 Summicron-R (11 345) | 1998 | 1000 |
| 3840500 | 3841499 | 50mm f/2 Summicron-R | 1998 | 1000 |
| 3868617 | 3869616 | 50mm f/2 Summicron-R | 1999 | 1000 |
| 3916023 | 3917022 | 50mm f/2 Summicron-R (11 345) | 2001 | 1000 |
| unknown | unknown | 50mm f/2 Summicron-R | 2006-2009 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1976-2001 | 99,736 |
