Summicron-S 100mm f/2 ASPH.
- Order no. - 11056
- Variants - Limited 100 Edition Set (100-ES) with Leica S camera (see Forum discussion [1] #16 below)
- Optical design
- Aspherical surfaces - 2 Floating Element Design
- Position of entrance pupil (at infinity /closest focusing distance) - 13 mm /38 mm (in light impingement direction in front of the bayonet flange)
- Luminous intensity - 1 : 2 (equiv to 1.6 KB format.)
- Focal length - 100 mm (equivalent to 80 mm 35 mm format)
- Angle of view (diagonal, horizontal, vertical) - Approx. 29°, 24.7°, 16.4, equivalent to a focal length of approx. 80 mm in 35 mm format
- Focusing range
- Working range - 0.7 m to ∞
- Smallest object field /Largest reproduction ratio - Approx. 144 × 217 mm /1 : 5
- Aperture
- Settings/function - Electronically controlled aperture settings
- Aperture Range - f/2 - f/22
- Construction details
- Lens mount - Leica S quick-change bayonet with contact strip for Leica S-Models
- Filter mount - Outer bayonet mount for lens hood (included), threaded mount for E82 filters, non-rotating filter mount
- Material - Dust & Water-Sealed anodized aluminum
- Length to bayonet flange - Approx. 102 /146 mm (with /without lens hood)
- Largest diameter - Approx. 91 /104 mm (with /without lens hood)
- Weight - Approx. 910 /965 g (with /without lens hood)
- Scope of delivery - Lens with 12402 lens hood, rear cap, lens front cap E82, carrying bag, manual, warranty card, certificate and optical cleaning cloth.
Leica Summicron-S 100mm f/2 ASPH. Serial Numbers
Serial numbers compiled from known Summicron-S 100mm f/2 ASPH. lenses| SN Start | SN End | Product | Year | Total |
| -4235402 | unknown- | Summicron-S 100mm f/2 ASPH. | 2014 | unknown |
| -unknown | 4302169- | Summicron-S 100mm f/2 ASPH. (100-ES) | 2014 | 100 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2014-Current | unknown |
