Epson SureColor P800
- Printer name & order no. - SureColor P800; SCP800SE
- Production era - 2015-current
- Base Printing Technology
- MicroPiezo AMC Print Head
- 8-channel, drop-on-demand, inkjet printhead
- Epson UltraChrome HD ink
- Professional-level pigment-based ink technology
- 9 Cartridges - (Photo Black, Matte Black, Light Black, Light Light Black, Cyan, Light Cyan, Vivid Magenta, Vivid Light Magenta, Yellow)
- Printer Nozzle Configuration
- Color and Monochrome - 180 nozzles each ink
- Enhanced Variable Droplet technology - as small as 3.5 picolitres
- Resolution - 2880 x 1440 dpi; 1440 x 720 dpi; 720 x 720 dpi; 720 x 360 dpi
- Dimensions - 26.93 in (W) x 14.80 in (D) x 9.85 in (H)
- Weight - 43 lbs
- Acoustic Noise Level - Color Printing; Approximately 50 dB(A) according to ISO 7779
- Operating Systems Supported - Windows 8, Windows 7 (32-bit or 64-bit); Macintosh X 10.10, 10.9, 10.8, 10.7 (system tested also worked with 10.6.8)
- Printer Interfaces & Language
- One Hi-Speed USB 2.0 port
- One Ethernet port - (10/100Base-T)
- Wireless - n(*), WiFi Direct subject to the range of the router being used. WiFi Direct may require printer software
- Support - Apple AirPrint and Google Cloud Print
- Sheet Media Handling
- Auto Sheet Feeder - 0.08-0.11mm
- Front Fine Art Feed - 0.29-0.70mm
- Front Straight Path - 1.20-1.50mm
- Maximum Media Width - 17 Inches
- Minimum Media Width - 3.5 Inches
- Maximum Printable Length - 22 Inches
- Minimum Media Length - 5 Inches
- Margins - each side - 0.12 Inches (3mm)
- Border Free Sizes - 3.5" x 5", 4" x 6", 5" x 7", 5"x8", 8" x 10", A4 (8.3" x 11.7"), letter (8.5" x 11"), 10"x12", 11" x 14", 11" x 17", A3 (11.7" x 16.5") and Super B (13" x 19"), 16" x 20", A2 (16.5" x 23.5"), 17" x 22"
- Border Free Expansion - Retain Size, Auto (Min., Mid, Max.)
- Accessories - Roll Media Adapter C12C811431
- Media Thickness - 0.25-0.70mm
- Maximum Roll Media Width - 17 Inches
- Minimum Roll Media Width - 13 Inches
- Top Margin - 1.97 Inches (50mm)
- Bottom Margin - 0.55 Inches (14mm)
- Left and Right Margin - 0.12 Inches (3mm)
- Border Free Widths - 13", 16", 16.5", 17"
- Expansion Method - Retain Size, Auto (fixed at max.)
- Roll Media Length - Manual Cut to Desired Length
- Accessories - Replacement Maintenance Tank T582000
