Vario-Elmarit-SL 24–90 mm f/2.8–4 ASPH.
Revision as of 16:37, 28 October 2015 by Tdavis (talk | contribs) (Created page with "400px *'''Order no.''' - 11176 :'''Production era''' - 2015-Current *'''Angle of view (diagonal, horizontal, vertical)''' - at 24 or 90mm: approx. 82,4°, 7...")
  • Order no. - 11176
Production era - 2015-Current
  • Angle of view (diagonal, horizontal, vertical) - at 24 or 90mm: approx. 82,4°, 72,1°, 51,8° or 27,8°, 23,3°,15,7
  • Number of lenses /groups - 18 /15
Aspherical surfaces - 4
  • Position of entrance pupil - at 24 or 90mm: 103,9 or 92,6mm (in the direction of light incidence in front of the bayonet fitting contact area)
  • Image stabilization - Multiple axis system, stabilization performance 3.5 shutter speed stages in accordance with CIPA testing conditions
  • Distance setting - Setting either automatic (Auto-focus) or manual, modes are set on the camera
  • Focusing range - at 24 or 90mm: 0.3 or 0.45m to ∞ Smallest object field/biggest scale - at 24 or 90mm: approx. 173 x 260mm /1:7.2 or 92 x 137mm /1:3.8
Aperture - Setting/Function electronically controlled aperture, setting via turn/push wheel on camera, half values can also be set
  • Lowest value - 22
  • Bayonet fitting - Leica L bayonet fitting with contact strip
  • Filter mount /lens hood - External bayonet fitting for lens hood (included), internal thread for E82 filters, filter mount does not rotate
  • Finish - Black anodized
  • Dimensions and weight - Length of the bayonet fitting contact surface:
at 24 or 90mm, (without/with lens hood) approx. 138/170mm or 182/212mm
  • Largest diameter approx - 88 mm
  • Weight approx - 1140 g
  • Warranty - 2 years
