35mm f/2.5 Summarit-M
Revision as of 16:03, 31 October 2015 by Tdavis (talk | contribs) (→35mm f/2.5 Summarit-M Serial Numbers)
- Leica Order No. - 11643
- Production era 2007-2014 - superseded by 35mm f/2.4 Summarit-M ASPH.
- Lens mount - Leica M quick-change bayonet with 6 bit lens identification bar code for digital M models
- Number of lenses /groups - 6 /4
- Focusing range - 0.8 m / 2.62 ft < ∞
- Aperture - f/2.5 - f/16 - Setting/Function Preset, with click-stops, half values available; 9-blade
- Smallest object field/Largest reproduction ratio - For 35 mm, approx. 490 x 735 mm /1:20.4 = for LEICA M8, approx. 367 x 551 mm /1:20.4
- Angle of view (diagonal, horizontal, vertical) - For 35 mm (24 x 36 mm) : 63 deg, 54 deg, 38 deg, - for LEICA M8 (18 x 27 mm) : 50 deg, 42 deg, 29 deg, corresponds to a focal length of approx. 47 mm with 35 mm-format
- Position of entrance pupil - (related to the first lens surface in light direction) 9.3 mm
- Filter mount/Lens hood - Non-rotating, internal thread for screw-on filters size E39, external thread with stop for lens hood, protection ring for external thread included in delivery
- Accessories - Hood: 12459
- Materials - Anodized aluminum, brass and optical glass
- Focal length -
- Length to bayonet flange - approx. 33.9 mm
- Largest diameter - approx. 51.4 mm / 2.02 in
- Weight - approx. 220 g / 7.76 oz
- Inscription - LEICA SUMMARIT-M 1:2.5/35 E 39 (serial no.)
- Leica Tech Data - 35mm f/2.5 Summarit-M.pdf
- On the street - $US 1,895 in 2012 - 1,595 in 2008
Serial numbers compiled from known lenses| SN Start | SN End | Product | Year | Total |
| -4049183 | 4063533- | 35mm f/2.5 Summarit-M | 2007-08 | 14,351+ |
| -4102070 | 4125785- | 35mm f/2.5 Summarit-M | 2009-12 | 23,716+ |
| -4151005 | 4168648- | 35mm f/2.5 Summarit-M | 2013 | 17,644+ |
| -unknown | 4233953- | 35mm f/2.5 Summarit-M | 2014 | unknown+ |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2007-2014 | unknown |
