Lens Coding
| Lens | Lens Coding | Value | Order No. black | Order No. chrome | Other lenses |
| Elmarit-M 21mm f/2.8 | 000001 | 1 | 11134 | ||
| Elmarit-M 28mm f/2.8 (III) | 000011 | 3 | 11804 | ||
| Tele-Elmarit-M 90mm f/2.8 (II) | 000100 | 4 | 11800 | ||
| Summilux-M 50mm f/1.4 (II) | 000101 | 5 | 11868 | 11856 | |
| Summicron-M 35mm f/2 (IV) | 000110 | 6 | 11310 | 11311 | Zeiss Biogon T* 2/35 ZM |
| Summicron-M 90mm f/2 (II) | (000111) | (7) | 11136 | 11137 | |
| Elmarit-M 135mm f/2.8 (I/II) | 001001 | 9 | 11829 | ||
| Tri-Elmar-M 16-18-21mm f/4 ASPH. | 010000 | 16 | 11626 | ||
| Summicron-M 50mm f/2 (III) | (010111) | (23) | 11817 | ||
| Elmarit-M 21mm f/2.8 ASPH. | 011000 | 24 | 11135 | 11897 | Voigtländer Color Skopar 21mm 1:4,0 Zeiss Biogon T* 2,8/21 ZM Kobalux 21mm f/2.8 |
| Elmarit-M 24mm f/2.8 ASPH. | 011001 | 25 | 11878 | 11898 | Voigtländer Snap Shot Skopar 25mm 1:4,0 Zeiss Biogon T* 2,8/25 ZM (with mount fix) |
| Summicron-M 28mm f/2 ASPH. | 011010 | 26 | 11604 | Voigtländer Ultron 28mm 1:1,9 Zeiss Biogon T* 2,8/25 ZM | |
| Elmarit-M 28mm f/2.8 (IV) | 011011 | 27 | 11809 | ||
| Elmarit-M 28mm f/2.8 ASPH. | 011100 | 28 | 11606 | Voigtländer Color Skopar 28mm 1:3,5 Zeiss Biogon T* 2,8/28 ZM | |
| Summilux-M 35mm f/1.4 ASPH. | 011101 | 29 | 11874 | 11883 | |
| Summicron-M 35mm f/2 ASPH. | 011110 | 30 | 11879 | 11882 | Voigtländer Color Skopar 35mm 1:2,5 Voigtländer Ultron 35mm 1:1,7 |
| 11821 | |||||
| Noctilux-M 50mm f/1 | 011111 | 31 | 11822 | ||
| Summilux-M 50mm f/1.4 ASPH. | 100000 | 32 | 11891 | 11892 | Voigtländer Nokton 50mm 1:1,5 Zeiss C Sonnar T* 1,5/50 ZM |
| 11819 11826 |
11825 | ||||
| Summicron-M 50mm f/2 (IV, V) | 100001 | 33 | 11816 | Zeiss Planar T* 2/50 ZM | |
| Elmar-M 50mm f/2.8 | 100010 | 34 | 11831 (11824) |
11823 | |
| Summilux-M 75mm f/1.4 | 100011 | 35 | 11810 11814 11815 |
| Apo-Summicron-M 75mm f/2 ASPH. | 100100 | 36 | 11637 | ||
| Apo-Summicron-M 90mm f/2 ASPH. | 100101 | 37 | 11884 | 11885 | |
| Elmarit-M 90mm f/2.8 | 100110 | 38 | 11807 | 11808 | |
| Macro-Elmar-M 90mm f/4 | 100111 | 39 | 11633 | 11634 | |
| Macro-Adaptor-M | 101000 | 40 | 14409 | ||
| Tri-Elmar-M 28-35-50mm f/4 ASPH. | 101010 | 42 | 11890 11625 |
11894 |
To draw your lens code, use the following diagram as a guide. An example has been provided. If you prefer to draw the code while holding the lens code area towards the top, use the top diagram, otherwise use the bottom diagram.
