D
Revision as of 22:08, 14 July 2009 by Admin (talk | contribs) (New page: {| class="prettytable" !Leica Code !Description !Production Year !Remarks |- | DACMO||Replacement for core spools ||?|| - |- | DACNO||Replacement for core spools||?|| - |- | DAMCO||Repl...)
DACMO Replacement for core spools ? -
DACNO Replacement for core spools ? -
DAMCO Replacement spool ? -
DANCO Replacement spool for 120 film ? -
DAMOT U.S. Code for BINDOMAT 1949 -
DAMOX U.S. Code for BINDOMAT 1953 -
DBOOF -
DBZOO -
DCBOO -
DCOOE -
DECIMAR Binoculars – 10 x 60 – 5.8 deg 1937-1959 -
DECIMARIT Binoculars – 10 x 60 – 5.8 deg – CF type 1937-1959 -
DEEMH Bulb for Molna BEECH microscope lamp ? -
DEEML Bulb for Molna BEECH microscope lamp ? -
DEEMN Bulb for Molna BEECH microscope lamp ? -
DEEMO ? -
DEEMP Bulb for Molna BEECH microscope lamp ? -
DEEQK Lamp system for microscope side lighting -
DEFOO Spiral developing tank, 400 ml 1938 -
DEOOC Small CHICO flash, capacitor type, with ivory plastic housing ? -
DEOOG Small CHICO flash, capacitor type, with black plastic housing ? -
DFHOO Small CHICO flash, capacitor type for Leica IIf and Leica IIIf ? -
DFOOB Flash bracket of ivory plastic 15609
DFOOF Small CHICO flash, capacitor type for Leica IIf and Leica IIIf with cable ? -
DGKOO Flash cable to connect CHICO to other cameras ? 15612
DHMOO Plastic box, ivory, for CHICO ? -
DHLOO Plastic box, black, for CHICO ? -
DIOOY Diopter check wheel from -5 to +4 ? -
DIREKT Self-timer 1932 -
DIROM Self-timer 1935 -
DIRON Self-timer for periods of up to 10 ½ sec. 1936 New York version
DLUUW -
DMUOO Visoflex intermediate ring used to attach Summicron 50 mm to bellows or enlarger No. 17672 ? -
DNWOO M>L39 adapter ring for Focomat IIc -
DOBOR -
DOOCQ Focotar 4.5/50, adapted for the Reprovit II -
DOOHF Focotar 4.5/50 1953-1975 17581
DOOIT Magnifying lens Elmar f3, 5 50mm ?-1953 replaced by the Focotar 1:4.5 50mm (I)
DOOLU Spirit Bubble Level -
DOORX Extension ring for Focotar -
DOOLU/S Spirit level accessory shoe, in black, nickel or chrome 1929-1939 -
DOOSL 25” clamp bracket for micro stand SPMOO ? -
DRXOO Aluminum containers for cassettes and later, there were other versions for 2 cassettes, Code Unknown ? -
DTEEO MONLA microscope lamp green filter ? -
DTEEP Green filter for photo purposes ? -
DUFAN New York filter, Dufaycolor Type A ? -
DUFAS New York filter, Dufaycolor Type C ? -
DUFAT New York filter, Dufaycolor Type D ? -
DUFUZ New York filter, Dufaycolor Type E ? -
DUFEN New York filter, Dufaycolor for emphasis ? -
DUFEP New York filter, Dufaycolor for Kodachrome ? -
DUFES New York filter, Dufaycolor for Kodachrome professional conversion filter ? -
DUFEX New York filter, Dufaycolor for flash Kodachrome ? -
DUFEZ New York filter, Dufaycolor for Kodachrome, Skylight ? -
DUFTU New York filter, Dufaycolor Type B for tungsten ? -
DUUER -
DUUNV -
DUUOI -
DUUPW -
DUUQK -
DUUVZ -
DUUXA Prado 150 projector with Dimaron 10 cm 1:2.8 lens 1948-ca.1967 -
DUUYO Prado 150 projector with Hektor 8.5 cm 1:2.5 lens 1948-ca.1967 -
DXOOK Rubberized shoulder strap ? -
DXOOL Rubberized shoulder strap 1962 -
DXOOM Dark leather shoulder strap ? -
DXOON Calf leather shoulder strap with rubber top ? -
DZUUH -
EAWOO -
EBOOH Everready leather case for R3 ca.1961 14615 Q
ECUUG ca.1961 37033 B
EDCUU ca.1961 37044 N
EDUUF ca.1961 37066 L
EELUD -
EEPMG Macro lamp, a circle with 4 x 25 W bulbs ? -
EEPLG Macro lamp, a circle with 4 x 40 W bulbs ? -
EEPSV Small holder for auxiliary GUHII, for screw mounting to the macro state MADAH ? -
EEPSU Larger holder for auxiliary GUHII, for screw mounting to the macro state MADAH ca. 1956 -
Tapered bellows for large format with tape measure -
EEXRL Holder for ISOFLEX ? -
EEXRM Holder for ISOFLEX ca.1955 -
EEXSN Holder for ISOFLEX with hammer paint finish ? -
EEZYX Slide device MACRODIA for macro photography ? -
EFERN Elmar f= 13.5 cm 1:4.5 nickel finish ? -
EFGUU ca.1961 37088 K
EGIUU ca.1961 37077 P
EGOOI -
EGUUC ca.1961 37099 N
EITPL -
EKURZ Elmar f= 3.5 cm 1:3.5 chrome finish 1933-1950 -
EKURZUP Elmar f= 3.5 cm 1:3.5 nickel finish 1930-1933 -
EKUUZ ca.1961 32600 G
ELANG Elmar (II) f= 9 cm 1:4 1930-1945 -
ELANG-M Elmar 90mm f/4 1954-1968 -
ELCAR Early close-up lens for Compur Leica (model B) ? -
ELCAT Late close-up lens for Compur Leica (model B) 1930 -
ELCOM Early close-up lens for Compur Leica (model B) diopter No. 2 ? -
ELCON Late close-up lens for Compur Leica (model B) diopter No. 2 ? -
ELCUR Early close-up lens for Compur Leica (model B) diopter No. 3 ? -
ELCUS Late close-up lens for Compur Leica (model B) diopter No. 3 ? -
ELDIA Contact printer for 35 mm negatives pre 1937 -
ELDUR Contact printer to make 2 x 2” lantern slides pre 1937 -
ELDUS -
ELESS -
ELGAM Elmar (II) f= 9 cm 1:4 (M) 1964-1963 11 830
ELGLA Metal pressure plate for ELDUR contact printer pre 1937 -
ELKIM Movie window panel 18x24 cm for contacts from Cinema negatives ? -
ELKIN Movie window panel 18x24 cm for contacts from Cinema negatives ? -
ELKOO -
ELMAR Elmar (I) f= 5 cm 1:3.5 1931-1959 -
ELMAM F = 5 cm 1:3.5 Elmar with M-bayonet 1954-1961 11 610
ELMOM F = 5 cm 1:2.8 Elmar with M-bayonet 1958-1966 11 612
ELMOO Elmar f= 5 cm 1:2.8 1957-1962 -
ELPAS Close-Up lens no.1 for dial-set Compur Leica (model B) 1927 -
ELPET Close-up lens No. 3 for Elmar ? -
ELPEX Close-up lens No. 3 for Summar ? -
ELPEZ Close-up lens No. 3 for Summitar ? -
ELPIK Close-up lens No. 2 for Elmar ? -
ELPIL Close-up lens No. 2 for Summar ? -
ELPIS Close-up lens No. 2 for Summitar ? -
ELPRO Close-up lens No. 1 for Elmar ? -
ELPUR -
ELPYN -
ELRIM Elmarit f= 9 cm 1:2.8 1959-1974 -
ELRIT Elmarit f= 9 cm 1:2.8 1959-1963 11 029
ELROO Elmar f= 3,5 1:4, “snap-shot” lens, prototype only ca.1950 -
ELRUU -
ELUUY -
ELZEN The “montain Elmar” Elmar f= 10.5 cm 1:6.3 1932-1937 -
EMQOO -
EMTOO Telyt leather case 14585 B
EMTUU 32620 T
EMUUX 32630 V
ENUUW -
ERKOM 11128 M
ESFOO Ready bag for LEICA 250 -
ESFUS Everready leather case for Leica IIIc -
ESNEL Everready leather case for Leica Ia -
ETXBE Small bellows, used with EEXSN and Aristophot II micro-photgraphy ? -
ETXBS Small bellows, used with Aristophot II micro-photgraphy ? -
EUKOS Everready case for Standard Leica (model E) -
EUKUT Deerskin purse for one lens filter pre 1934 -
EUROS -
EUVER -
EUVIL Morocon leather purse for one lens filter pre 1934 -
EXCOR -
EUDIT Leather case for FODUA Leica I (model A) ? -
EYMZE 6-volt lamp housing with a focusing objective, and 2 blue glass filters ? -
EYMZG 6-volt lamp housing with a focusing objective, and 2 green glass filters ? -
EYMZH 6-volt lamp housing with a focusing objective, and 2 filters ? -
EZDOO Leather strap for 125mm Hektor -
