STUVWXYZ
| Leica Code | Description | Production Year | Remarks | |||||
| SAIOO | "Sports" viewfinder for Hektor f= 7.3 cm 1:1.9 lens | ? | - | |||||
| SAMWO | F = 3.5 cm 1:2 Summicron I for M3 | 1958-1969 | 11 108 - 9,557 pieces | |||||
| SAWOM | 35mm f/2 Summicron II for M2 | 1958-1969 | 11 308 – 11,935 pieces | |||||
| SAWOO | Summicron (I) f= 3.5 cm 1:2 | 1958-1963 | 11 008 ~500 pieces | |||||
| SBLOO | Finder for SOONC-M Summaron f= 3.5 cm 1:3.5 | ca.1956-1960 | - | |||||
| SCNOO | Rapid winder for Leica IIIa (model G), Leica IIIb | ca.1937 | - | |||||
| SEROO | "Sports" viewfinder for 9 cm lens | ? | - | |||||
| SEOOF | Summicron (I) f= 9 cm 1:2 | 1959-1962 | ||||||
| SEOOF-M | Summicron (I) f= 9 cm 1:2 | made in Canada only | ||||||
| SEOOM | Summicron (II) f= 9 cm 1:2 | 1959-1979 | - | |||||
| SGVOO | 90mm viewfinder/bright finder (12025) | 1951-? | - | |||||
| SIMOM | Summaron f= 35 mm 1:2.8 for M3 | 1958-1974 | - | |||||
| SIMOO | Summaron f= 3.5 cm 1:3.5 | 1958-1963 | - | |||||
| SIMOW | Summaron f= 35 mm 1:2.8 for M2 | 1958-1974 | - | |||||
| SIUUB-Glas | Parvo 100 / Prado 100 projector with Hektor 2.5/8.5cm | 1949-1950 | - | |||||
| SLOOZ | Viewfinder, 28 mm, black or chrome | 1960-? | 12007 | |||||
| SMUUY | Parvo 100 / Prado 100 projector with condenser I (f. 7.3-10cm) | 1949/ 1950 | - | |||||
| SNOOX | Summaron f= 2.8 cm 1:5.6 | 1955-1963 | - | |||||
| SOMKY | Close focus accessory for collapsible version of the Summicron or Elmar 50mm lens, and with the front element of the fixed Summicron with the use of an adapter called UOORF | ? | also called SOOKY-M | |||||
| SOMNI | Summicron (II) f= 5 cm 1:2 | 1956-1968 | 11 818 | |||||
| SOOBK | Hood for Summaron f= 2.8 cm 1:5.6 | ? | - | |||||
| SOOCX | Summarex f= 8.5 cm 1:1.5 | 1948-1960 | - | |||||
| SOODL | Viewfinder, 50 mm | ca.1950 | - | |||||
| SOOHN | Hood for Hektor f= 2.8 cm 1:6.3 | ? | - | |||||
| SOOIA | Summarit f= 5 cm 1:1.5 | 1949-1960 | - | |||||
| SOOIA-M | F = 5 cm 1:1.5 Summarit | 1952-? | ||||||
| SOOIC | Summicron (I) f= 5 cm 1:2 | 1953-1960 | - | |||||
| SOOKY | Close focus accessory for rangefinder Elmar 5c lens with parallax | ? | - | |||||
| SOOKY-M | See SOMKY | ? | - | |||||
| SOOME | Summilux (I) f= 5 cm 1:1.4 | 1959-1961 | - | |||||
| SOONC | Summaron f= 3.5 cm 1:3.5 | 1948-1960 | - | |||||
| SOONC-M | Summaron f= 3.5 cm 1:3.5 | 1956-1960 | - | |||||
| SOONC-MW | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M3 | 1956-1960 | - | |||||
| SOONC-MT | Summaron f= 3.5 cm 1:3.5 with viewfinder for the M2 | 1957-1960 | - | |||||
| SOORE | Summitar f= 5 cm 1:2 | 1939-1955 | - | |||||
| SOOZI | Summicron (I) f= 9 cm 1:2 | 1957-1959 | - | |||||
| SUMAR | Summar f= 5 cm 1:2 | 1933-1940 | - | |||||
| SUOON | Super-Angulon f= 2.1 cm 1:4 | 1958-1963 | - | |||||
| SUUHN | Parvo 100 / Prado 100 projector with condenser II (f. 5cm Summar/ Sumwithar) | 1949-1950 | - | |||||
| SUUAI | Parvo 100 / Prado 100 projector with condenser III (f. 5cm Elmar/ Summar) | 1949-1950 | - | |||||
| SUUZI | Film strip holder for projectors | 1952 | - | |||||
| SYEOO | "Sports" viewfinder for 13.5 cm lens | ? | - | |||||
| SYOOM | Rapid winder for Leica IIIf or Leica IIIg | ca.1953 | - | |||||
| TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - | |||||
| TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - | |||||
| TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - | |||||
| TUVOO | Attachment for VIOOH viewfinder for 2.8 cm lenses | ? | - | |||||
| UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - | |||||
| UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - | |||||
| UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - | |||||
| UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - | |||||
| UCWQU | 1960 | - | ||||||
| UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - | |||||
| UDLSU | 1960 | - | ||||||
| UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - | |||||
| UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - | |||||
| UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - | |||||
| UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - | |||||
| UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - | |||||
| UCHRU | Protective metal hood for Pradovit I | 1960 | - | |||||
| UCSHU | Remote control cable 4m long | 1960 | - | |||||
| UGPXU | Remote control cable 10m long | 1960 | - | |||||
| UGQZU | Remote control cable 15m long | 1960 | - | |||||
| UGRBU | Remote control cable 20m long | 1960 | - | |||||
| UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - | |||||
| UEOXU | Slide magazine for 30 slides | 1960 | - | |||||
| UFBXU | 5 magazine cassette | 1960 | - | |||||
| UDWPU | Transparent container for 2 slide magazines | 1960 | - | |||||
| UDXRU | Transparent containers with 2 magazines | 1960 | - | |||||
| UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - | |||||
| UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - | |||||
| UKGDU | Synchronous circuit with tape | 1960 | - | |||||
| UHPWU | Multiple connector for tape device and cable | 1960 | - | |||||
| UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | ? | 16596 | |||||
| UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - | |||||
| UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 | |||||
| UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 | |||||
| UOOST | UOOYW + UOOVH | ? | - | |||||
| UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 | |||||
| UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 | |||||
| UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 | |||||
| UOOYW | Bellows connecting ring for I and II | ? | 16590 N | |||||
| UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 | |||||
| UOSWU | Horizontal slider for Prado S and SM | ? | - | |||||
| UUOYW | Adapter ring and tube | ? | - | |||||
| UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - | |||||
| VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - | |||||
| VIDOM | Viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | ||||||
| VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on | _ | VISET | Torpedo shaped finder for 3.5cm, 5cm, 9cm, 13.5cm lenses | ca.1930 | - |
| WINKO | Angle viewfinder for Standard Leica (model E) | ? | - | |||||
| WINTU | Angle viewfinder for Leica II, III & IIIa with swing-in prism for right angle focus | ? | - | |||||
| XEMOO | Xenon f= 5 cm 1:1.5 (Schneider) | 1936-1950 | - | |||||
| XOONS | Lens hood for Summarit 1:1.5 / 5 cm | ? | - | |||||
| YAROB | Magnifying lens | ? | - | |||||
| ZOOEP | Short, chrome focusing mount for the Summicron M 2/90 mm to Visoflex II / III | 16462 |
