Leica 0
Revision as of 15:48, 7 August 2009 by Admin (talk | contribs)
0-34.jpg Preproduction series of 31 cameras, Serial #100-130, hand-made in 1923 & 1924. Since the focal plane shutter was not self capping on the first seven examples, they required the use of a lens cap which was attached with a cord to a small bracket on the camera body. This feature was retained on the second batch even though they had a self-capping shutter. The viewfinder is located directly above the lens. (Image and data courtesy of Massimo Bertacchi)
  • Zeiss Anastigmat Lens - LLC - 112
  • Production era - 1920-1925
  • Variants - non-self-closing and self-closing lens
  • Lens mount - Fixed to camera
  • Number of lenses /groups - 4 /3
  • F stop range - f/3.5 > f/12
  • Closest focusing distance -
  • Smallest object field -
  • Diaphragm setting /type -
  • Filter type -
  • Accessories -
  • Materials - Lacquered brass
  • Weight - 135 g /
  • Inscription - Leitz Anastigmat 1:3,5 F=50mm
  • Designer - Oskar Barnack Zeiss lens design by Paul Rudolph (1858-1935)
