Leica 0
Preproduction series of 31 cameras, Serial #100-130, hand-made in 1923 & 1924. Since the focal plane shutter was not self capping on the first seven examples, they required the use of a lens cap which was attached with a cord to a small bracket on the camera body. This feature was retained on the second batch even though they had a self-capping shutter. The viewfinder (either folding or telescoping type) is located directly above the lens. (Image and data courtesy of Massimo Bertacchi ![]()
Leica Camera Drawing
- Anastigmat Lens - LLC - 112
- Production era - 1920-1925
- F stop range - f/3.5 > f/12
- Closest focusing distance -
- Smallest object field -
- Diaphragm setting /type -
- Filter type -
- Accessories -
- Materials - Lacquered brass
- Weight - 135 g /4.76 oz
- Designer - Oskar Barnack, Zeiss Anastigmat lens design by Paul Rudolph (1858-1935)
