R6
The Leica R6 is a mechanical, manual exposure, manual focus single-lens reflex camera which was on sale between 1988-92. Unlike every other entrant in the R-series range (with the exception of its successor the R6.2[1]), the R6's shutter is fully battery independent. The only element of the camera's operation which is dependent on battery power is the built-in exposure meter.
Perhaps the most famous devotee of the Leica R6/R6.2 cameras is reknowned documentary photographer Sebastio Salgado [2].
Specifications
- Viewfinder with 0.8x magnification factor, 92% coverage, +/- 2 diopter viewfinder correction
- Interchangeable focusing screens
- Vertical-travel metal blade focal-plane shutter with speeds 1 - 1/1000 sec + B and X (1/100sec)
- Battery self-check
- Eyepiece shutter
- Multiple-exposure
- Depth of field preview
- Electronic self-timer (nine second delay)
- Viewfinder illumination
- Mirror lock socket
- Manually controlled TTL diode-match meter system, requiring 2 x SR44 or 1 x CR1/3N cell(s)
- Supports 35mm film of speeds 12-3200ASA
- Dimensions: 138.5 x 89.1 x 62.2mm
- Weight: 625g
- Finishes: Silver or black chrome
R6 Serial Numbers
| SN Start | SN End | Product | Year built | Batch |
| 1724451** | 1728450** | Leica M6 Schwz | 1987 | 4000** |
| 1728451 | 1732450 | Leica R6 Schwz | 1987 | 4000 |
| 1745451 | 1755450 | Leica R6 Schwz | 1988 | 10000 |
| 1765751 | 1768000 | Leica R6 Hell | 1989 | 2250 |
| 1770486 | 1772500 | Leica R5 & R6 Hell | 1989 | 2015 |
| 1775001 | 1777000 | Leica R5 & R6 Hell | 1990 | 2000 |
| 1777501 | 1779000 | Leica R6 & R-E | 1990* | 2500 |
| 1782001 | 1783000 | Leica R5, R6, R-E | 1990 | 1000 |
| Total | assigned | serial numbers | 1987-1990 | >27,765 |
. * Serial numbers and batch total from Gandy's List
** Serial numbers from Serial Numbers Leica Cameras with computed batch total.
Unmarked SN's match between both lists and Gandy's batch total was used without recalculation.
