C2
Production era - September 1, 2002-2005
Order no. - 18 110.
Type - Compact 35 mm autofocus viewfinder camera with zoom lens.
Lens - 35–70 mm f/4.6–8.6 LEICA VARIO-ELMAR (7 elements in 6 groups).
Focus range - 0.6 m /2 ft < infinity. Smallest object field - 190 x 285 mm.
Autofocus system - Passive phase-detection multi-zone infrared autofocus.
Exposure control - Programmed automatic exposure control with automatic flash activation (Auto), flash on, flash off, Auto with stroboscopic pre-flash for red-eye reduction, Auto Slow (with longer exposure time)
Exposure metering - Center-weighted two-zone metering sensor with backlight recognition.
Memory - Focus is locked and metered value saved with light pressure on shutter release button.
Shutter speed range - 1/330 s < 2 s
Film speed setting - Automatic film speed setting for DX-coded films from ISO 50/18° to ISO 3200/36° ; Films without DX-coding and films with speeds under ISO 50/18° are set at ISO 100/21° ; Films with speeds over ISO 3200/36° are set at ISO 3200/36°.
Flash range with ISO 100 slide film - Wide-angle : 3 m (10ft) ; Telephoto : 1.63 m (5 ft 4") ; Guide number : 14 (46 ft)
Viewfinder - Real-image type zoom viewfinder with display of flash, autofocus and exposure metering symbols. 0.35 x with 35 mm to 0.67 x with 70 mm ; field of view is approximately 80 % of film format
Film transport - Automatic film threading and advance to first frame. Automatic rewind after last exposure. Midroll rewind possible.
Data imprinting - Integrated ; Imprinting of date or day and time.
Exposure series - The exposure series function is activated when the release button is pressed continuously.
Self-timer 10 sec. exposure delay.
Power supply - 3V lithium battery (CR 123A).
Body - Silver aluminum. Side attachment for carrying strap or wrist strap. Tripod thread A1/4 DIN 403 (1/4").
Weight - 240 g /8.5 oz without batteries.
Dimensions (W x H x D) - 121 x 66 x 39.5 mm /4 4/5x 2 5/8x 1 9/16 in.
Accessories - Leather case with belt loop, cable elease.
C2 Serial Numbers
| SN Start | SN End | Product | Year built | Batch |
| 2817001 | 2847000 | Leica C2 | 2002 | 30,000 |
| Inital | assigned | serial numbers | 2002 only | 30,000 |
Serial numbers from Serial Numbers Leica Cameras with computed batch total.
