F
Revision as of 23:34, 14 September 2009 by Admin (talk | contribs)
FARBA ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 1934-1935 -
FARLY FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 ca.1933 -
FAROS FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 ca.1933
FARPU ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 1934-1935 -
FARUX Panoramic tripod head 1933-1936 -
FASKI FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 ca.1933
FAVOO No. 2 medium yellow filter; screw-on type H ca.1935 -
FAWAG FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 ca.1933
FAXIS FARUX Scale ring for Elmar (I) f= 9 cm 1:4 ca.1933
FAZOY No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 ca.1933-1938 NY item
FBOOK UVa filter; screw-on type H ca.1935 -
FBXOO Panchromatic green no. 1 filter; screw-on type H ca.1935 -
FCKOO Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 1951-1960 -
FCOOI No. 2 medium infra-red filter; screw-on type H ca.1935 -
FCZOO No. 1 light infra-red filter; screw-on type F ca.1931 -
FDOOH No. 3 dark infra-red filter; screw-on type G ca.1935 -
FEARM Copy arm used with FESSA base and FEHUN column 1931-19?? -
FEDOO No. 1 light infra-red filter; slip-on type A36 ca.1931-1950 13040
FEFFU Copy base and column, used with FILUM arm and STALI lighting = FEPRO 1931-19?? -
FEHUN Column support used with FESSA base and FEARM 1931-19?? -
FEOOG No. 3 dark infra-red filter; slip-on type A36 ca.1935 13050
FEPRO Copy stand with FEFFU base, column, FILUM arm and STALI lighting 1931-19?? used with front lenses 2 & 3, WICAP and WINKO
FESSA Copy base used with FEHUN column and FEARM 1931-19?? -
FESTO Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting 1931-19?? used with front lenses 1, 2 or 3, WICAP and WINKO
FGHOO Replacement hood for Hektor f= 7.3 cm 1:1.9 1936-1946 -
FGOOE No. 1 light infra-red filter; screw-on type I ca.1933 -
FHKOO Single film holder for I, II, III, IIIa, IIIb1 1935-1960 -
FHOOD No. 3 dark infra-red filter; screw-on type I ca.1935 -
FIAKU Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate 1926-19?? -
FIALT Holder for film handling during the development process 1930's -
FIAMA Panoramic tripod head for 5 cm lens 1926-19xx -
FIARO ? 19xx-19xx -
FIATE ? 19xx-19xx -
FIAVI ? 19xx-19xx -
FIBLA ? 19xx-19xx -
FIBOB No. 2 medium infra-red filter; screw-on type G ca.1933 -
FIBOS ? 19xx-19xx -
FICAT No. 1 light yellow filter; screw-on type F ca.1930 -
FICFA Kodachrome type A filter; ADFIK 34 mm mount ca.1949- -
FICHR Kodachrome flash filter; slip-on type A36 ca.1949- -
FICOM No. 2 medium yellow filter; screw-on type F ca.1930 -
FICOR Panchromatic green no. 2 filter; slip-on type A36 ca.1945 NY item
FICUR No. 3 dense yellow filter; screw-on type F; ca.1930 -
FIDAY Kodachrome type F filter; screw-on type L ca.1959- -
FIDAYMI Kodachrome type A filter; screw-on type E39 ca.1949- NY item
FIDRI ? 19xx-19xx -
FIEKT ? 19xx-19xx -
FIFLO Kodachrome photo-flood filter; screw-on type L ca.1949- NY item
FIFLOMI Kodachrome photo-flood filter; screw-on type E39 ca.1949- NY item
FIGAM No. 2 medium yellow filter; slip-on type A36 ca.1931-1950 -
FIGDA ? 19xx-19xx -
FIGIL Graduated Yellow filter; slip-on type C ca.1931 -
FIGON ? 19xx-19xx -
FIGRO No. 1 light yellow filter; slip-on type A36 ca.1931-1950 13005
FIGUN No. 1 light yellow filter; ADFIK 34 mm mount ca.1945 NY item
FIHAZ Kodachrome haze filter; screw-on type L ca.1949- NY item
FIHEL No. 0 very light yellow filter; slip-on type A36 ca.1933 13000
FIIRL ? 19xx-19xx -
FIKAT Kodachrome type A filter; slip-on type A36 ca.1949- NY item
FIKHA Kodachrome type A filter; ADFIK 34 mm mount ca.1949- NY item
FIKLO Kodachrome photo-flood filter; slip-on type A36 ca.1949- NY item
FIKOZ Kodachrome haze filter; slip-on type A36 ca.1949- NY item
FIKUS ? 19xx-19xx -
FIKYB No. 2 medium infra-red filter; slip-on type A36 ca.1933-1950 -
FILBY No. 1 light yellow filter; slip-on type A ca.1926 -
FILCA ? 19xx-19xx -
FILES ? 19xx-19xx -
FILGE No. 2 medium yellow filter; slip-on type A ca.1925 -
FILOY ? 19xx-19xx -
FILPO ? 19xx-19xx -
FILSO No. 1 light yellow filter; slip-on type C ca.1933 -
FILTU No. 3 dense yellow filter; slip-on type A ca.1925-1926 -
FILUM Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO 1931-19?? -
FILXA No. 3 dense yellow filter; screw-on type I ca.1933 -
FILYT ? 19xx-19xx -
FIMOO No. 0 very light yellow filter; screw-on type H ca.1935 -
FINON ? 19xx-19xx -
FINOT ? 19xx-19xx -
FINOW ? 19xx-19xx -
FINUS No. 3 dense yellow filter; screw-on type G ca.1931 NY item
FIOKO UVa filter; screw-on type F ca.1931 -
FIOLA UVa filter; slip-on type A36 ca.1931 13055
FIOMU No. 2 medium infra-red filter; slip-on type C ca.1933 -
FIONA ? 19xx-19xx -
FIOOC No. 1 light yellow filter; screw-on type H ca.1935 -
FIOPY No. 0 very light yellow filter; slip-on type C ca.1933 -
FIORE UVa filter; screw-on type G ca.1931 -
FIOSI UVa filter; slip-on type C ca.1933 -
FIOUX FSEOO Orange filter; slip-on type A36 ca.1939 NY item
FIPAN ? 19xx-19xx -
FIPHO Kodachrome photo flood filter; ADFIK 34 mm mount ca.1949- NY item
FIPLO No. 2 medium infra-red filter; screw-on type I ca.1933 -
FIPOS Panchromatic green no. 1 filter; slip-on type A36 ca.1933-1950 13015
FIPPA No. 2 medium yellow filter; slip-on type C ca.1933 -
FIQUX Orange filter; slip-on type A36 ca.1939-1950 NY item
FIRAD Graduated Yellow filter; slip-on type A36 ca.1931 -
FIRCO ? 19xx-19xx -
FIREG No. 1 light yellow filter; screw-on type I ca.1933 -
FIRGI ? 19xx-19xx -
FIRHE No. 1 light yellow filter; screw-on type G ca.1931 13001
FIRHU ? 19xx-19xx -
FIRMY No. 2 medium yellow filter; screw-on type G ca.1931 -
FIROL ? 19xx-19xx -
FIRYX Panchromatic green no. 1 filter; screw-on type I ca.1933 -
FISAP Panchromatic green no. 1 filter; slip-on type C ca.1933 -
FISEX ? 19xx-19xx -
FISKF ? 19xx-19xx -
FISON ? 19xx-19xx -
FISUM ? 19xx-19xx -
FISUMMI ? 19xx-19xx -
FITAF ? 19xx-19xx -
FITWO ? 19xx-19xx -
FIUNS No. 0 very light yellow filter; slip-on type A ca.1933 -
FIVPL
FIWAS No. 0 very light yellow filter; screw-on type I ca.1933 -
FIWET UVa filter; screw-on type I ca.1933 -
FIWIG No. 2 medium yellow filter; screw-on type I ca.1933 -
FIXIO Panchromatic green no. 1 filter; screw-on type G ca.1933 -
FIXLA ? 19xx-19xx -
FIXTA No. 0 very light yellow filter; screw-on type G ca.1933 -
FKDELM Kodachrome type F filter; slip-on type A36 ca.1959- -
FKDSAX Kodachrome type F filter; screw-on type E58 ca.1959- -
FKDSMI Kodachrome type F filter; screw-on type E39 ca.1959- -
FKDSMT Kodachrome type F filter; screw-on type E41 ca.1959- -
FKDTEL Kodachrome type F filter; screw-on type E48 ca.1959- -
FLASH ? 19xx-19xx -
FLECT ? 19xx-19xx -
FLOOA ? 19xx-19xx -
FLOTH ? 19xx-19xx -
FLQOO ? 19xx-19xx -
FMOOZ No. 1 light infra-red filter; slip-on type C ca.1933 -
FMSOO No. 3 dark infra-red filter; slip-on type C ca.1935 -
FNOOY No. 1 light infra-red filter; screw-on type H ca.1935 -
FNUOO No. 3 dark infra-red filter; screw-on type H ca.1935 -
FODIS ? 19xx-19xx -
FOFER ? 19xx-19xx -
FOKAL ? 19xx-19xx -
FOKIN ? 19xx-19xx -
FOKOS ? 19xx-19xx -
FOKUX ? 19xx-19xx -
FONOR ? 19xx-19xx -
FONOT ? 19xx-19xx -
FOOBD Graduated Green filter; slip-on type A36 ca.1938 -
FOOCR Graduated Green filter; slip-on type C ca.1938 -
FOOKH ? 19xx-19xx -
FOOMI ? 19xx-19xx -
FOONW FARUX Scale ring for Hektor 2.8 cm ca.1936
FOOQL FARUX Scale ring for Telyt 20 cm ca.1936
FOOVA ? 19xx-19xx -
FOOXB Filter holder; slip-on type A36 ca.1951 13365
FOOXC Filter holder; screw-on type L ca.1951 -
FOOXD Filter holder; screw-on type E41 ca.1951 13375
FOOXE Filter holder; screw-on type E58 ca.1951 13380
FOOXF Filter holder; screw-on type E48 ca.1951 13385
FOOXH Filter holder; screw-on type E39 ca.1955 13371
FOOXK Filter holder; screw-on type E43 ca.1959 13384
FOSAR ? 19xx-19xx -
FPKELM Kodachrome type FP filter; slip-on type A36 ca.1959- -
FPKSAX Kodachrome type FP filter; screw-on type E58 ca.1959- -
FPKSMI Kodachrome type FP filter; screw-on type E39 ca.1959- -
FPKSMT Kodachrome type FP filter; screw-on type E41 ca.1959- -
FPLTEL Kodachrome type FP filter; screw-on type E48 ca.1959- -
FPOOW Orange filter; screw-on type G ca.1939 -
FQOOV Orange filter; screw-on type H ca.1939 -
FRCOO Orange filter; screw-on type I ca.1939 -
FSEOO Orange filter; slip-on type C ca.1939-1950 -
FTGOO Orange filter; slip-on type A36 ca.1939 13025
FUECD ? 19xx-19xx -
FUFIF ? 19xx-19xx -
FUFOR ? 19xx-19xx -
FULDY ? 19xx-19xx -
