TUV
TBKOO | Microscope to camera connector with correction lens | 1939-19?? | - |
TELOO | F = 20 cm 1:4 Telyt | 1956-1966 | - |
TEQOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13326 |
TFOOG | Yellow very light no. 0 filter; screw-on type E85 | ca.1938 | 13291 |
TFSOO | Yellow light no. 1 filter; screw-on type E85 | ca.1938 | 13296 |
TGOOF | Yellow medium no. 2 filter; screw-on type E85 | ca.1938 | - |
TGUOO | Infra-red light no. 1 filter; screw-on type E85 | ca.1938 | 13316 |
THMOO | Replacemant hood for F = 40 cm 1:5 Telyt I | 1951-1955 | see also TMEOO |
THOOE | Infra-red medium no. 2 filter; screw-on type E85 | ca.1938 | 13316 |
THWOO | Infra-red dark no. 3 filter; screw-on type E85 | ca.1938 | 13326 |
TIOOD | UVa filter; screw-on type E85 | ca.1938 | 13331 |
TIYOO | Panchromatic green filter; screw-on type E85 | ca.1938 | 13306 |
TLCOO | F = 40 cm 1:5 Telyt II | 1956-1966 | - |
TMEOO | Replacemant hood for F = 40 cm 1:5 Telyt II | 1954-1966 | see also THMOO |
TNGOO | Replacemant hood for f = 20 cm 1:4 Telyt | 1954-19?? | see also THMOO |
TOODY | Thambar f= 9 cm 1:2.2 | 1935-1939 | - |
TOOQE | 85 | 19??-19?? | - |
TOOSF | 84 | 19??-19?? | - |
TOOUG | 85 | 19??-19?? | - |
TOWIN | 37 | 19??-19?? | - |
TREPL | 80 | 19??-19?? | - |
TROOV | 85 | 19??-19?? | - |
TRPOO | 85 | 19??-19?? | - |
TRPOO-M | - | 19??-19?? | - |
TSOOV | 85 | 19??-19?? | - |
TUSOO | 61-2 | 19??-19?? | - |
TUVOO | Attachment for VIOOH viewfinder for 2.8 cm lenses | ? | 12-13 |
TXBOO | 17-109 | 19??-19?? | - |
TZFOO | - | 19??-19?? | - |
TZOON | - | 19??-19?? | - |
1 | |||
UBECD | 59 | 19??-19?? | - |
UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - |
UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - |
UCHRU | Protective metal hood for Pradovit I | 1960 | - |
UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - |
UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - |
UCSHU | Remote control cable 4m long | 1960 | - |
UCWQU | 1960 | - | |
UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - |
UDIMO | 59 | 19??-19?? | - |
UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
UDWPU | Transparent container for 2 slide magazines | 1960 | - |
UDXRU | Transparent containers with 2 magazines | 1960 | - |
UDLSU | 1960 | - | |
UEOOK | 47 | 19??-19?? | - |
UEOXU | Slide magazine for 30 slides | 1960 | - |
UEPOO | 47 | 19??-19?? | - |
UFBXU | 5 magazine cassette | 1960 | - |
UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
UGPXU | Remote control cable 10m long | 1960 | - |
UGQZU | Remote control cable 15m long | 1960 | - |
UGRBU | Remote control cable 20m long | 1960 | - |
UHPWU | Multiple connector for tape device and cable | 1960 | - |
UKGDU | Synchronous circuit with tape | 1960 | - |
UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
UNOOB | 58-74 | 19??-19?? | - |
UNOOB-YSMOO | 58 | 19??-19?? | - |
UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | 1956-19?? | 16596 |
UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 |
UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 |
UOOST | UOOYW + UOOVH | ? | - |
UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 |
UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 |
UOOYH | 48 | 19??-19?? | - |
UOOYW | Bellows connecting ring for I and II | ? | 16590 N |
UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 |
UOSWU | Horizontal slider for Prado S and SM | ? | - |
UPOOZ | Yellow very light no. 0 filter; screw-on type E58 | ca.1951 | 13235 |
UQMOO | Yellow light no. 1 filter; screw-on type E58 | ca.1951 | 13235 |
UQOOY | Yellow medium no. 2 filter; screw-on type E58 | ca.1951 | - |
UROOX | Panchromatic green filter; screw-on type E58 | ca.1951 | 13245 |
USFLA | Kodachrome flash filter; type E58 | 1949-19?? | NY item |
USOAY | Kodachrome type A filter; type E58 | 1949-19?? | NY item |
USOOW | Orange filter; screw-on type E58 | ca.1951 | 13250 |
USQOO | - | 19??-19?? | - |
USSKY | Kodachrome skylight filter; type E58 | 1954-19?? | NY item |
UTOOV | Infra-red medium no. 2 filter; screw-on type E58 | ca.1951 | - |
UTSOO | Infra-red dark no. 3 filter; screw-on type E58 | ca.1951 | 13265 |
UUOYW | Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND | 1956-19?? | - |
UVOOF | UVa filter; screw-on type E58 | ca.1951 | 13270 |
UVWOO | 71-2 | 19??-19?? | - |
UWOOS | 67-8-9 | 19??-19?? | - |
UWYOO | 47-8 | 19??-19?? | - |
UXOOR | 47 | 19??-19?? | - |
UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - |
UZEOO | 47 | 19??-19?? | - |
VALOY | 67-8 | 19??-19?? | - |
VAMAX | 68 | 19??-19?? | - |
VARIP | 74 | 19??-19?? | - |
VEARM | 68-74 | 19??-19?? | - |
VEDUK | Cable with plug and switch for VEKAS | 1931-19?? | - |
VEHAL | Bent camera arm with wingnut; used with VERAP | 1931-19?? | - |
VEHIG | 53-74 | 19??-19?? | - |
VEKAS | 16 x 20 inch lightbox with 6 lights, VEDUK cable and various glass covers to hold film flat; on base of VERAP | 1931-19?? | - |
VEKOT | 72 | 19??-19?? | - |
VELIF | 68-74 | 19??-19?? | - |
VELTU | 68-74 | 19??-19?? | - |
VELYP | 72 | 19??-19?? | - |
VEPUT | 16 x 12 inch lightbox with 4 lights, VEDUK cable and various glass covers, VELYP to hold film flat | 1932-19?? | - |
VERAP | X-ray reproduction device with VESTA base and column, VEHAL arm and VEKAS light box with VEHIG and 12 feet of cable with switch | 1931-19?? | - |
VERYK | 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and various glass covers, VEYRK to hold film flat; on base of VERAP | 1932-19?? | - |
VESTA | Base and column; used with VERAP | 1931-19?? | - |
VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - |
VIDEO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses | 1932-1933 | black |
VIDOM | Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | |
VIEFF | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
VIEME | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses | 1932-1933 | black |
VIFUR | Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1933-1936 | black or chrome |
VIGEH | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
VIHAK | 74 | 19??-19?? | - |
VIHEU | Small, torpedo shaped finder for 3.5cm, 5cm lenses | 1932- | black |
VIKAN | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VIKUL | 9 1/2 x 12 inch lightbox with 3 lights and various glass covers, VIRUP to hold film flat | 1933-19?? | - |
VILLO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VIOAD | 12 | 19??-19?? | - |
VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on |
VISAX | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1932-1933 | black |
VISET | Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
VISIL | 10 | 19??-19?? | - |
VISOR | The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1931-1931 | black |
VISSI | Small, torpedo shaped finder for 3.5cm, 9cm lenses | 1932-1933 | black |
VITRE | Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses | 1933-1936 | black or chrome |
VIUNA | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses | 1933-1936 | black or chrome |
VIZWO | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1933-1936 | black or chrome |
VLOOF | 95 | 19??-19?? | - |
VMCOO | 40 | 19??-19?? | - |
VOOLA | 104-5 | 19??-19?? | - |
VOOQF | 67 | 19??-19?? | - |
VORGI | 40 | 19??-19?? | - |
VOROD | 35 | 19??-19?? | - |
VORSA | 35 | 19??-19?? | - |
VORSTAN | 35 | 19??-19?? | - |
VORUF | 36 | 19??-19?? | - |
VOSTN | 35 | 19??-19?? | - |
VOTIV | 36 | 19??-19?? | - |
VOTRA | 36 | 19??-19?? | - |
VSPOO | 60 | 19??-19?? | - |
VTOOX | 60 | 19??-19?? | - |
VTROO | 60 | 19??-19?? | - |
VUROO | 67 | 19??-19?? | - |
VWOOU | 60 | 19??-19?? | - |
VXOOT | 60 | 19??-19?? | - |
VXZOO | 60 | 19??-19?? | - |
