TUV
Revision as of 13:55, 20 September 2009 by Admin (talk | contribs)
TBKOO Microscope to camera connector with correction lens 1939-19?? -
TELOO F = 20 cm 1:4 Telyt 1956-1966 -
TEQOO Infra-red light no. 1 filter; screw-on type E85 ca.1938 13326
TFOOG Yellow very light no. 0 filter; screw-on type E85 ca.1938 13291
TFSOO Yellow light no. 1 filter; screw-on type E85 ca.1938 13296
TGOOF Yellow medium no. 2 filter; screw-on type E85 ca.1938 -
TGUOO Infra-red light no. 1 filter; screw-on type E85 ca.1938 13316
THMOO Replacemant hood for F = 40 cm 1:5 Telyt I 1951-1955 see also TMEOO
THOOE Infra-red medium no. 2 filter; screw-on type E85 ca.1938 13316
THWOO Infra-red dark no. 3 filter; screw-on type E85 ca.1938 13326
TIOOD UVa filter; screw-on type E85 ca.1938 13331
TIYOO Panchromatic green filter; screw-on type E85 ca.1938 13306
TLCOO F = 40 cm 1:5 Telyt II 1956-1966 -
TMEOO Replacemant hood for F = 40 cm 1:5 Telyt II 1954-1966 see also THMOO
TNGOO Replacemant hood for f = 20 cm 1:4 Telyt 1954-19?? see also THMOO
TOODY Thambar f= 9 cm 1:2.2 1935-1939 -
TOOQE Small, table top tripod complete with FOOMI ball and socket 1952-19?? -
TOOSF 84 19??-19?? -
TOOUG Small, table top tripod complete with FOOMI ball and socket; black crackle enamel; later gray enamel 1952-19?? 14100
TOWIN 37 19??-19?? -
TREPL Complete photomicrography outfit with microscope, mirror reflex housing and copy stand 1938-19?? -
TROOV Leather wrist strap with threaded connector 1938-19?? -
TRPOO Neck strap with patent hooks 1951-19?? -
TRPOO-M Neck strap with patent hooks for Leica-M 1956-19?? -
TSOOV Neck strap with split rings for atachment to camera side lugs; later version has non-slip shoulder pad 1960-19?? 14092
TUSOO Steel tape measure for ROOFU arm 1951-19?? -
TUVOO Chrome attachment for VIOOH viewfinder for 2.8 cm lenses ? -
TXBOO Extension tube for TEYLT's on M-cameras 19??-19?? 14024
TZFOO Extension tube for TEYLT's on screw cameras 19??-19?? -
TZOON Extension tube for TEYLT's on screw cameras, early version 19??-19?? 14023
1
UBECD 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar 1936-1940 NY item
UCEGU Pradovit I with Dimaron 2.8/100mm 1960 -
UCFKU Pradovit I with Colorplan 2.5/90mm 1960 -
UCHRU Protective metal hood for Pradovit I 1960 -
UCNXU Pradovit f with Dimaron 2.8/100mm 1960 -
UCPLU Pradovit f with Colorplan 2.5/90mm 1960 -
UCSHU Remote control cable 4m long 1960 -
UCWQU 1960 -
UDCBU Pradovit f with Dimaron 2.8/150mm 1960 -
UDIMO Enlarger 19??-19?? -
UDGKU Plywood case for projector plus accessories and 150mm lenses 1960 -
UDKQU Second heat protection filter, including 500-watt lamp 1960 -
UDWPU Transparent container for 2 slide magazines 1960 -
UDXRU Transparent containers with 2 magazines 1960 -
UDLSU 1960 -
UEOOK Adaptor ring for UZEOO 36 mm front lens mount 19??-19?? 16568
UEOXU Slide magazine for 30 slides 1960 -
UEPOO Adaptor ring for UZEOO 42 mm front lens mount 19??-19?? 16566
UFBXU 5 magazine cassette 1960 -
UFTGU 2 slide magazines for 50 slides incl. cardboard 1960 -
UGPXU Remote control cable 10m long 1960 -
UGQZU Remote control cable 15m long 1960 -
UGRBU Remote control cable 20m long 1960 -
UHPWU Multiple connector for tape device and cable 1960 -
UKGDU Synchronous circuit with tape 1960 -
UMHDU Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable 1960 -
UMIQU Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable 1960 -
UMKHU Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable 1960 -
UMLKU Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable 1960 -
UMNOU Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable 1960 -
UNOOB Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar f= 5 cm 1:3.5 1934-19?? -
UNOOB-YSMOO Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for [[Summar f= 5 cm 1:2 1937-19?? -
UOOND Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW 1956-19?? 16596
UOOPE Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb ? -
UOORE Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M ? 16508
UOORF Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY 1960 16508
UOOST UOOYW + UOOVH ? -
UOOVH Lens adapter ring for the head of Hector and Elmar 135mm ? 16580
UOOWV Lens Adapter Ring for heads and the Elmarit 90mm Elmar ? 16585
UOOXI Adapter Ring Lens fü the head of the 125mm Hektor 1958 16572
UOOYW Bellows connecting ring for I and II ? 16590 N
UOOZK Adapter ring for the head of the Summicron 90 mm 1960 16598
UOSWU Horizontal slider for Prado S and SM ? -
UPOOZ Yellow very light no. 0 filter; screw-on type E58 ca.1951 13235
UQMOO Yellow light no. 1 filter; screw-on type E58 ca.1951 13235
UQOOY Yellow medium no. 2 filter; screw-on type E58 ca.1951 -
UROOX Panchromatic green filter; screw-on type E58 ca.1951 13245
USFLA Kodachrome flash filter; type E58 1949-19?? NY item
USOAY Kodachrome type A filter; type E58 1949-19?? NY item
USOOW Orange filter; screw-on type E58 ca.1951 13250
USQOO Infra-red light no. 1 filter; screw-on type E58 ca.1951 13255
USSKY Kodachrome skylight filter; type E58 1954-19?? NY item
UTOOV Infra-red medium no. 2 filter; screw-on type E58 ca.1951 -
UTSOO Infra-red dark no. 3 filter; screw-on type E58 ca.1951 13265
UUOYW Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND 1956-19?? -
UVOOF UVa filter; screw-on type E58 ca.1951 13270
UVWOO 4-way lamp socket with cable and plug 1951-19?? 16760
UWOOS Arm connector for copy stand Focoslide 19??-19?? 16601
UWYOO Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU 1951-19?? 16600
UXOOR Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f- 13.5 cm 1:6.3; later version has thread for universal focusing bellows II with interchangable adaptor rings 1951-19?? 16555
UYOOQ Fiber case with Visoflex I, bellows and accessories ? -
UZEOO Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount 1951-19?? 16565
UZEOO-M Bellows lens hood for 42 mm front lens mount 1960-19?? 16567
VALOY Complete copy stand type I and II OKYNO 19??-19?? -
VAMAX X-ray enlarger used with VEHAL and 48" VESTA arm 1933-19?? -
VARIP Large copying device with VELTU base and column, and VEARM arm and STAFO lighting, VEHIG and STAMA 1933-19?? -
VEARM Large copying device with 40" VELTO base and column, front lenses 1, 2 & 3 and VALFA or FILYT enlarger 1933-19?? -
VEDUK Cable with plug and switch for VEKAS 1931-19?? -
VEHAL Bent camera arm with wingnut; used with VERAP 1931-19?? -
VEHIG Fixed focusing stage with ground glass housing complete with 5x magnifier and protecting lid for camera body opening 1933-19?? -
VEKAS 16 x 20 inch lightbox with 6 lights, VEDUK cable and various glass covers to hold film flat; on base of VERAP 1931-19?? -
VEKOT 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and VERYK glass covers to hold film flat 1931-19?? -
VELIF Arm for VIHAK small copy stand 1933-19?? -
VELTU Base and column part of VARIP or ROOKA large copy stand 1933-1936 -
VELYP 16 x 12 inch glass covers to hold film flat 1933-19?? -
VEPUT 16 x 12 inch lightbox with 4 lights, VEDUK cable and various glass covers, VELYP to hold film flat 1932-19?? -
VERAP X-ray reproduction device with VESTA base and column, VEHAL arm and VEKAS light box with VEHIG and 12 feet of cable with switch 1931-19?? -
VERYK 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and various glass covers, VEYRK to hold film flat; on base of VERAP 1932-19?? -
VESTA Base and column; used with VERAP 1931-19?? -
VEZUK Curved lateral holder to support the camera when used vertically ca.1933 -
VIDEO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses 1932-1933 black
VIDOM Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image 1933-1939
VIEFF Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses 1932-1933 black
VIEME Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses 1932-1933 black
VIFUR Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1933-1936 black or chrome
VIGEH Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses 1932-1933 black
VIHAK 74 19??-19?? -
VIHEU Small, torpedo shaped finder for 3.5cm, 5cm lenses 1932- black
VIKAN Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIKUL 9 1/2 x 12 inch lightbox with 3 lights and various glass covers, VIRUP to hold film flat 1933-19?? -
VILLO Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses 1932-1933 black
VIOAD 12 19??-19?? -
VIOOH Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm 1940-1964 reaches 2.8 cm with TUVOO add-on
VISAX Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1932-1933 black
VISET Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses 1932-1933 black
VISIL 10 19??-19?? -
VISOR The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses 1931-1931 black
VISSI Small, torpedo shaped finder for 3.5cm, 9cm lenses 1932-1933 black
VITRE Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses 1933-1936 black or chrome
VIUNA Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses 1933-1936 black or chrome
VIZWO Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses 1933-1936 black or chrome
VLOOF Spare, folding reflector for CEYOO, CEYAL or CAVOO 1951-1953 15532
VMCOO Intermediate ring for use of Elmar front lenses on 5 cm Summar 19??-19?? -
VOOLA Thin metal diaphram setting ring to adjust aperature of 5 cm Elmar when slip-on filter is in place 1955-19?? 16621
VOOQF 32 inch copy stAND column with guide rail like Valoy II OVURO ca.1955 17552
VORGI Intermediate ring for use of Hektor front lenses on 5 cm Summar 19??-19?? -
VOROD Sereoly system for Leica II, III and IIIa 1932 NY item
VORSA Early Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa 1931-1939 -
VORSTAN Sereoly system for non-rangefinder cameras 1933-1934 -
VORUF Stereoly arm to mount prisum on Leica II, III and IIIa ca.1939 -
VOSTN Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa 1935-1939 -
VOTIV Stand for VOTRA stereo transparency viewer; nickel plated 1931-19?? -
VOTRA Stereo transparency viewer; nickel plated 1931-19?? -
VSPOO Focusing mount for Focoslide OOBAZ or OTGOO using F = 5 cm 1:2 Summicron II 1956-1968 16608
VTOOX Aperature setting ring for 50mm f/2.8 Elmar-M 1958-19?? 16622
VTROO Aperature setting ring for 60 mm f/2.2 Summicron-M 1956-19?? 16686
VUROO Valloy II copy stand with 25 1/2 inch column including UWOOS bracket to take FOCOSLIDE 1960-19?? 16702 16704-3/8" bush
VWOOU Repro N extension tub 26mm fitted between Focoslide OOBAZ or OTGOO 1956-19?? 16689
VXOOT Focusing mount for Focoslide OOBAZ using F = 5 cm 1:3.5 Elmar and VALOO aperature setting ring 1958-19?? 16622
VXZOO Focusing mount for Focoslide OOBAZ or OTGOO using 50mm f/2.8 Elmar-M 1958-19?? 16608
