PQR
| PAMOO | Right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I | 1940-1962 | |
| PCOOB | Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PEGOO | Visoflex I, 45 degree 4x eyepiece; black with rubber eyepiece | 1951-1962 | 16487 |
| PEOOZ | Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PFOOY | Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PGOOX | Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PGYOO | Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PHOOW | UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PIOOV | Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PKOOU | Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PLGOO | Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PLOOT | Mirror reflex housing with flared eyepiece and double cable release | 1935-1951 | - |
| PMOOS | Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PNOOR | Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| POFLA | Kodachrome flash filter; screw-on type E48 | ca.1949 | NY item |
| POLAR | Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections | 1938-19?? | NY item |
| POOAH | Yellow filter no. 0 very light; screw-on type E48 | ca.1935 | 13290 |
| POOAY | Kodachrome filter type A; screw-on type E48 | ca.1949 | NY item |
| POOBV | Yellow filter no. 1 light; screw-on type E48 | ca.1935 | 13295 |
| POOCI | Yellow filter no. 2 medium; screw-on type E48 | ca.1935 | - |
| POOCQ | Blue filter; screw-on type E48 | ca.1955 | 13307 |
| POODW | Panchromatic filter no. 1; screw-on type E48 | ca.1935 | 13305 |
| POOEK | Infra-red filter no. 2; screw-on type E48 | ca.1935 | - |
| POOEL | Polarising filter; graduated, slip-on type A36 | ca.1939 | 13350 |
| POOFX | UVa filter; screw-on type E48 | ca.1935 | 13330 |
| POOGL | Infra-red filter no. 1; screw-on type E48 | ca.1935 | 13315 |
| POOHY | Infra-red filter no. 3; screw-on type E48 | ca.1935 | 13325 |
| POOIM | Chimney 5x flared eyepiece with swing-in 30x magnifier for PLOOT | 1935-1951 | - |
| POOKZ | Orange filter; screw-on type E48 | ca.1935 | 13310 |
| POOLN | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | - |
| POORE | Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 | ca.1949 | 13362 |
| POORQ | Double cable release for PLOOT mirror reflex housing | 1936-19?? | - |
| POOTR | Polarising filter; graduated, screw-on type E39 | ca.1939 | 13362 |
| POSKY | Kodachrome skylight filter; screw-on type E48 | ca.1949 | NY item |
| PROON | Pre Visoflex mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT | 1940-1950 | - |
| QBOOE | Yellow filter no. 3 dense; screw-on type H | ca.1935 | NY item |
| QCPOO | Yellow filter no. 3 dense; slip-on type A36 | ca.1931 | NY item |
| RAMET | Mask used with RASUK for 3.5 - 9 cm lenses | 19??-19?? | -14 |
| RASAL | RAMET + RASUK; chrome plated version = CHROM | 19??-19?? | - |
| RASUK | Lensless viewfinder for 10.5 & 13.5 cm lenses | 19??-19?? | - |
| RDQOO | Diaphragm operating lever and guide for lens on Reprovit II ROOXU | 1951-19?? | 16775 |
| REDIG-BEEUL | Resistor for 110 volt DC | 19??-19?? | - |
| REDUK-BEEUL | Resistor for 220 volt DC | 19??-19?? | - |
| REDYX | Regulating transformer for BEECH microscope light | 1934-19?? | - |
| REEOD | 74-61 | 19??-19?? | - |
| RESOO | 74 | 19??-19?? | - |
| RFUOO | Regulating transformer for RIOOZ | 1936-19?? | - |
| RGWOO | 61-2 | 19??-19?? | - |
| RIFLE | 46 | 19??-19?? | - |
| RIOOX | 78 | 19??-19?? | - |
| RIOOZ | Ring illuminator for l vi | 1936-19?? | - |
| RKCOO | 71-2-78 | 19??-19?? | - |
| ROOAI | 55-6-78 | 19??-19?? | - |
| ROOAM | 55 | 19??-19?? | - |
| ROOFU | 68-61-63-69-78 | 19??-19?? | - |
| ROOKA | 74-76 | 19??-19?? | - |
| ROOMB | 68-74 | 19??-19?? | - |
| ROONP | 68 | 19??-19?? | - |
| ROOSE | 78-9 | 19??-19?? | - |
| ROOXU | 78 | 19??-19?? | - |
| ROOYH | 59-78 | 19??-19?? | - |
| ROSOL | 14 | 19??-19?? | - |
| ROXUM | 78 | 19??-19?? | - |
| RPNOO | 63-4 | 19??-19?? | - |
| RPOOT | 63 | 19??-19?? | - |
| RQPOO | 101 | 19??-19?? | - |
| RSTOO | 63 | 19??-19?? | - |
| RTSOO | 63 | 19??-19?? | - |
| RWBOO | Deerskin pouch for RASAL | 19??-19?? | - |
