PQR
| PAMOO | Right angle 5x eyepiece; early version with mirror; later with prism; PAMOO + PROON = ODULO later used on Visoflex I | 1940-1962 | |
| PCOOB | Yellow filter no. 0 very light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PEGOO | Visoflex I, 45 degree 4x eyepiece; black with rubber eyepiece | 1951-1962 | 16487 |
| PEOOZ | Yellow filter no. 1 light; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PFOOY | Yellow filter no. 2 medium; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PGOOX | Graduated yellow filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PGYOO | Graduated green filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PHOOW | UVa filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PIOOV | Panchromatic filter no. 1 ; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PKOOU | Infra-red filter no. 1; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PLGOO | Orange filter; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PLOOT | Mirror reflex housing with flared eyepiece and double cable release | 1935-1951 | - |
| PMOOS | Infra-red filter no. 2; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| PNOOR | Infra-red filter no. 3; slip-on type D for Thambar f= 9 cm 1:2.2 and f = 20 cm 1:4 Telyt | ca.1935 | - |
| POFLA | Kodachrome flash filter; screw-on type E48 | ca.1949 | NY item |
| POLAR | Stereo transparency equipment to add to Leitz VII projector for viewing stereo projections | 1938-19?? | NY item |
| POOAH | Yellow filter no. 0 very light; screw-on type E48 | ca.1935 | 13290 |
| POOAY | Kodachrome filter type A; screw-on type E48 | ca.1949 | NY item |
| POOBV | Yellow filter no. 1 light; screw-on type E48 | ca.1935 | 13295 |
| POOCI | Yellow filter no. 2 medium; screw-on type E48 | ca.1935 | - |
| POOCQ | Blue filter; screw-on type E48 | ca.1955 | 13307 |
| POODW | Panchromatic filter no. 1; screw-on type E48 | ca.1935 | 13305 |
| POOEK | Infra-red filter no. 2; screw-on type E48 | ca.1935 | - |
| POOEL | Polarising filter; graduated, slip-on type A36 | ca.1939 | 13350 |
| POOFX | UVa filter; screw-on type E48 | ca.1935 | 13330 |
| POOGL | Infra-red filter no. 1; screw-on type E48 | ca.1935 | 13315 |
| POOHY | Infra-red filter no. 3; screw-on type E48 | ca.1935 | 13325 |
| POOIM | Chimney 5x flared eyepiece with swing-in 30x magnifier for PLOOT | 1935-1951 | - |
| POOKZ | Orange filter; screw-on type E48 | ca.1935 | 13310 |
| POOLN | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | - |
| POORE | Polarising filter; graduated, screw-on type L for Summitar f= 5 cm 1:2 | ca.1949 | 13362 |
| POORQ | Double cable release for PLOOT mirror reflex housing | 1936-19?? | - |
| POOTR | Polarising filter; graduated, screw-on type E39 | ca.1939 | 13362 |
| POSKY | Kodachrome skylight filter; screw-on type E48 | ca.1949 | NY item |
| PROON | Pre Visoflex mirror reflex housing; used with PAMOO = ODULO; used with POOIM = PLOOT | 1940-1950 | - |
| QBOOE | Yellow filter no. 3 dense; screw-on type H | ca.1935 | NY item |
| QCPOO | Yellow filter no. 3 dense; slip-on type A36 | ca.1931 | NY item |
| RAMET | Mask used with RASUK for 3.5 - 9 cm lenses | 19??-19?? | -14 |
| RASAL | RAMET + RASUK; chrome plated version = CHROM | 19??-19?? | - |
| RASUK | Lensless viewfinder for 10.5 & 13.5 cm lenses | 19??-19?? | - |
| RDQOO | Reprovit II diaphragm operating lever and guide for lens on ROOXU | 1951-19?? | 16775 |
| REDIG-BEEUL | Resistor for 110 volt DC | 19??-19?? | - |
| REDUK-BEEUL | Resistor for 220 volt DC | 19??-19?? | - |
| REDYX | Regulating transformer for BEECH microscope light | 1934-19?? | - |
| REEOD | Universal Copying Device consisting of VAFOO, RESOO, STUOO, GROOW, ZWOOC, UNOOB, TBKOO, LOOCG, LOOFV, LOOGI, LOOHW and LSZOO | 1936-19?? | - |
| RESOO | Carrying arm with OORES rotating upper stage | 1936-19?? | - |
| RFUOO | Regulating transformer for RIOOZ | 1936-19?? | - |
| RGWOO | Object stage to flatten books for copying | 1951-19?? | 16786 |
| RIFLE | 46 | 19??-19?? | - |
| RIOOX | Reprovit II base and column with arm, tape measure and switches | 19??-19?? | - |
| RIOOZ | Ring illuminator for Universal Copying Device | 1936-19?? | - |
| RKCOO | Reprovit 4-lamp unit | 1951-19?? | 16785 |
| ROOAI | Reprovit II focusing stage with bellows | 1951-19?? | 16770 |
| ROOAM | Reprovit II focusing stage with bellows with bayonet-mount | 1960-19?? | - |
| ROOFU | Reprovit I and Focoslide carrying arm to fit 1 5/8 inch column | 1951-19?? | -68-61-63-69-78 |
| ROOKA | Large copying device with VELTU base and column, ROOMB arm, STAFO lighting, VEHIG and STAMA | 1936-19?? | - |
| ROOMB | Arm for ROOKA large copying device used with VELTU base and arm | 1936-19?? | - |
| ROONP | Copy arm to fit 1 1/4 inch column for Focoslide | 1951-19?? | - |
| ROOSE | Reprovit I Universal Copying Device consisting of OVAFO, ROOFU, OOZAB, OUTSO, ZOOXY and VALOO | 19??-19?? | - |
| ROOXU | Reprovit II Universal Copying Device consisting of RIOOX, ROOAI, RDQOO, OUTSO, DOOCO and RKCOO | 1951-19?? | 16795, 16794-3/8" bush |
| ROOYH | 26 mm repro extension tube | 1951-19?? | -59-78 |
| ROSOL | 14 | 19??-19?? | - |
| ROXUM | Reprovit II for bayonet-mount Leica | 1960-19?? | 16796, 16793-3/8" bush |
| RPNOO | Reprovit micro-addaptor for focusing stage with shutter, eyepiece, correction lens and double cable release | 1951-19?? | - |
| RPOOT | Reprovit micro-addaptor for focusing stage without shutter, eyepiece or cable release | 1956-19?? | - |
| RQPOO | 101 | 19??-19?? | - |
| RSTOO | Reprovit micro-addaptor for focusing stage with shutter, eyepiece, 1/2x correction lens and double cable release | 1951-19?? | |
| RTSOO | Reprovit micro-addaptor for focusing stage with 1/2x correction lens but without shutter, eyepiece or cable release | 1956-19?? | - |
| RWBOO | Deerskin pouch for RASAL | 19??-19?? | - |
