D
DACMO | Replacement for core spools | ? | - |
DACNO | Replacement for core spools | ? | - |
DAMCO | Replacement spool | ? | - |
DANCO | Replacement spool for 120 film | ? | - |
DAMOT | U.S. Code for BINDOMAT | 1949 | - |
DAMOX | U.S. Code for BINDOMAT | 1953 | - |
DBOOF | - | ||
DBZOO | - | ||
DCBOO | - | ||
DCOOE | - | ||
DECIMAR | Binoculars – 10 x 60 – 5.8 deg | 1937-1959 | - |
DECIMARIT | Binoculars – 10 x 60 – 5.8 deg – CF type | 1937-1959 | - |
DEEMH | Iris diaphram for Molna BEECH microscope lamp | 1939 | - |
DEEML | Bulb for Molna BEECH microscope lamp | ? | - |
DEEMN | Bulb for Molna BEECH microscope lamp | ? | - |
DEEMO | ? | - | |
DEEMP | Bulb for Molna BEECH microscope lamp | ? | - |
DEEQK | Lamp system for microscope side lighting | - | |
DEFOO | Spiral developing tank, 400 ml | 1938 | - |
DEOOC | Small CHICO flash, capacitor type, with ivory plastic housing | 1954-1959 | - |
DEOOG | Small CHICO flash, capacitor type, with black plastic housing | ? | - |
DFHOO | Small CHICO flash, capacitor type for Leica IIf and Leica IIIf | 1954-1965 | - |
DFOOB | Flash bracket of ivory plastic | 19??-19?? | 15609 |
DFOOF | Small CHICO flash, capacitor type for Leica IIf and Leica IIIf with cable | ? | - |
DGKOO | Flash cable to connect CHICO to other cameras | ? | 15612 |
DHMOO | Plastic box, ivory, for CHICO | ? | - |
DHLOO | Plastic box, black, for CHICO | ? | - |
DIOOY | Diopter check wheel from -5 to +4 | 1955 | - |
DIREKT | Self-timer | 1932 | - |
DIROM | Self-timer | 1935 | - |
DIRON | Self-timer for periods of up to 10 ½ sec. | 1936 | New York version |
DLUUW | - | ||
DMUOO | Visoflex intermediate ring used to attach Summicron 50 mm to bellows or enlarger No. 17672 | ? | - |
DNWOO | M>L39 adapter ring for Focomat IIc | - | |
DOBOR | - | ||
DOOCQ | Focotar 4.5/50, adapted for the Reprovit II | - | |
DOOHF | Focotar 4.5/50 | 1953-1975 | 17581 |
DOOIT | Magnifying lens Elmar f3, 5 50mm | ?-1953 | replaced by the Focotar 1:4.5 50mm (I) |
DOOLU | Spirit Bubble Level | - | |
DOORX | Extension ring for Focotar | - | |
DOOLU/S | Spirit level accessory shoe, in black, nickel or chrome | 1929-1939 | - |
DOOSL | 25” clamp bracket for micro stand SPMOO | ? | - |
DRXOO | Aluminum containers for cassettes and later, there were other versions for 2 cassettes, Code Unknown | ? | - |
DTEEO | MONLA microscope lamp green filter | ? | - |
DTEEP | Green filter for photo purposes | ? | - |
DUFAN | Dufaycolor Type A | 1936 | NY item |
DUFAS | Dufaycolor Type C | 1936 | NY item |
DUFAT | Dufaycolor Type D | 1936 | NY item |
DUFUZ | Dufaycolor Type E | 1936 | NY item |
DUFEN | Dufaycolor for emphasis | 1936 | NY item |
DUFEP | Dufaycolor for Kodachrome | 1936 | NY item |
DUFES | Dufaycolor for Kodachrome professional conversion filter | ? | NY item |
DUFEX | Dufaycolor for flash Kodachrome | ? | NY item |
DUFEZ | Dufaycolor for Kodachrome, Skylight | ? | NY item |
DUFTU | Dufaycolor Type B for tungsten | 1936 | NY item |
DUUER | - | ||
DUUNV | - | ||
DUUOI | - | ||
DUUPW | - | ||
DUUQK | - | ||
DUUVZ | - | ||
DUUXA | Prado 150 projector with Dimaron 10 cm 1:2.8 lens | 1948-ca.1967 | - |
DUUYO | Prado 150 projector with Hektor 8.5 cm 1:2.5 lens | 1948-ca.1967 | - |
DXOOK | Rubberized shoulder strap | ? | - |
DXOOL | Rubberized shoulder strap | 1962 | - |
DXOOM | Dark leather shoulder strap | ? | - |
DXOON | Calf leather shoulder strap with rubber top | ? | - |
DZUUH | - |
