KL
| KGOON | Large ball and socket head; pre-war version had short body; later models have cross bar for connection leverage with combined 1/4 - 3/8" screw threads; 1959 version has a smooth wingnut; replaced by part #14121 | 1936-1964 | 14115 |
| KINOR | Cine model viewfinder for 15, 25, 50, 75 & 100 mm | ca.1983 | - |
| KINSU | Cine model viewfinder for 15-150 mm; like VIDOM with rubber eyecup and bracket for cine camera mounting | 1934-1982 | - |
| KOOAS | Dark slide for OLEYO/OLIGO single exposure housing | 1934-1982 | - |
| KOOBF | Film cassette for Leica 250 (models DD, FF & GG) | 1933-1937 | - |
| KOOBG | Film cassette for Leica 250 (models DD, FF & GG) | 1938-1953 | - |
| KOOCT | M1 body | 1959-1964 | 10125 |
| KOOHE | M2 body | 1957-1968 | - |
| KOVIR | Large transparency printer | 1933-1956 | - |
| KOVIS | Large transparency printer | 1957-1957 | - |
| KOVIZ | Large transparency printer | 1958-1959 | - |
| LEDYD | Early exposure meter known as "Leicascope" for the NY market; a separate, small, adjustable lens group not intended for camera mounting | ca.1934 | - |
| LEDZH | Early exposure meter known as "Weston Model 627" for the NY market (superseded by the improved "Weston Model 617" and the smaller "Model 650" of 1936) | ca.1934 | - |
| LEANEKALB | Leica I (model A) with calfskin cover and Elmar (I) f= 5 cm 1:3.5 lens | 1925-1936 | - |
| LECOM | Compur Leica (model B) with ETROS carrying case | ca.1931 | from 1931 Leica catalog |
| LECUR | Compur Leica (model B) body | 1926-1941 | - |
| LEICA | Leica I (model A) with Anastigmat or Elmax lens | 1925 | - |
| LELUX | Leica I (model A) gold plated, lizard skin cover with ELMAR Anastigmat lens | 1930 | - |
| LEMAX | Standard Leica (model E) body | 1932-1933 | later named ALVOO |
| LENEU | Leica I (model C) body | 1930-1933 | - |
| LFVOO | Large field 5x bayonet magnifier for focusing stage; postwar version was conical and later black | ca.1938-1948 | - |
| LGCOO | Simple 5x bayonet magnifier for focusing stage | ca.1938 | - |
| LKIOO | Large field angular 5x bayonet magnifier for focusing stage | ca.1938-1944 | - |
| LKOOM | Leica 72 (18 x 24 mm) body | 1957-1963 | - |
| LOOCG | Simple 5x slip-on magnifier for focusing stage | ca.1936 | - |
| LOOEL | Leica IIf with ELMAR lens | 1951-1956 | from 1955-58 catalog |
| LOOFV | 5x slip-on magnifier for focusing stage | ca.1936 | - |
| LOOGI | 5x right-angle slide-in magnifier for focusing stage | ca.1936 | - |
| LOOHW | Leica IIIc postwar body | 1946-1951 | - |
| LOOHW | 30x slip-on magnifier for focusing stage | ca.1936 | - |
| LOOIT | Leica IIIf with Summarit f= 5 cm 1:1.5 lens | 1951-1956 | from 1955-58 catalog |
| LOOMY | Leica 250 (models DD, FF & GG) body | 1933-1953 | - |
| LOOSE | Leica IIf body | 1951-1956 | from 1955-58 catalog |
| LOOSU | Leica IIf with Summitar 5 cm 1:2 | 1951-1956 | from 1955-58 catalog |
| LOOTP | Leica IIId body | 1939-1947 | - |
| LOOYE | Leica 250 (models DD, FF & GG) with Elmar (I) f= 5 cm 1:3.5 | 1933-1953 | - |
| LSZOO | Two light-excluding rings for connecting a microscope to a rotating focusing stage | ca.1936 | - |
| LUFAS | Object stage for photographing small objects | ca.1939 | - |
| LUOON | Leica IIf with Summicron (I) f= 5 cm 1:2 lens | 1951-1956 | from 1955-58 catalog |
| LUOOX | Leica IIIf with Summicron (I) f= 5 cm 1:2 lens | 1951-1956 | from 1955-58 catalog |
| LVFOO | Visoflex 5x vertical eyepiece | 1951-1962 | 16486 |
| LWHOO | 30x bayonet magnifier for focusing stage | ca.1938 | - |
| LYCAN | Leica II (model D) early body, black | 1932-1934 | - |
| LYKEH | Leica II (model D) with Hektor f= 5 cm 1:2.5, black | 1932-1934 | - |
| LYKUP | Leica II (model D) with Elmar (I) f= 5 cm 1:3.5, black | 1932-1933 | ABOOT 1934-1948 |
| LYDRO | Leica III (model F) black body | ca.1933 | from the 1933 Leica catalog |
