F
Leica Code | Description | Production Year | Remarks | ||
FARBA | ELW Afgacolor filter 301 for "taking" lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - | ||
FARLY | FARUX Scale ring for Elmar 13.5 cm or Hektor f= 7.3 cm 1:1.9 | ca.1933 | - | ||
FAROS | FARUX Scale ring for Elmar (I) f= 5 cm 1:3.5 | ca.1933 | |||
FARPU | ELW Afgacolor filter 351 for projection lens used with Hektor f= 7.3 cm 1:1.9 and Summar f= 5 cm 1:2 | 1934-1935 | - | ||
FARUX | Panoramic tripod head | 1933-1936 | - | ||
FASKI | FARUX Scale ring for Elmar f= 10.5 cm 1:6.3 | ca.1933 | |||
FAVOO | No. 2 medium yellow filter; screw-on type H | ca.1935 | - | ||
FAWAG | FARUX Scale ring for Hektor f= 7.3 cm 1:1.9 | ca.1933 | |||
FAXIS | FARUX Scale ring for Elmar (I) f= 9 cm 1:4 | ca.1933 | |||
FAZOY | No. 3 dense yellow filter; screw-on type H; superseded by OBOOE in 1939 | ca.1933-1938 | NY item | ||
FBOOK | UVa filter; screw-on type H | ca.1935 | - | ||
FBXOO | Panchromatic green no. 1 filter; screw-on type H | ca.1935 | - | ||
FCKOO | Single film holder for Ic, IIc, IIf, IIIc, IIIf to sn. 590681 | 1951-1960 | - | ||
FCOOI | No. 2 medium infra-red filter; screw-on type H | ca.1935 | - | ||
FCZOO | No. 1 light infra-red filter; screw-on type F | ca.1931 | - | ||
FDOOH | No. 3 dark infra-red filter; screw-on type G | ca.1935 | - | ||
FEARM | Copy arm used with FESSA base and FEHUN column | 1931-19?? | - | ||
FEDOO | No. 1 light infra-red filter; slip-on type A36 | ca.1931-1950's | 13040 | ||
FEFFU | Copy base and column, used with FILUM arm and STALI lighting = FEPRO | 1931-19?? | - | ||
FEHUN | Column support used with FESSA base and FEARM | 1931-19?? | - | ||
FEOOG | No. 3 dark infra-red filter; slip-on type A36 | ca.1935-1950's | 13050 | ||
FEPRO | Copy stand with FEFFU base, column, FILUM arm and STALI lighting | 1931-19?? | used with front lenses 2 & 3, WICAP and WINKO | ||
FESSA | Copy base used with FEHUN column and FEARM | 1931-19?? | - | ||
FESTO | Copy stand with FESSA or FEHUN column and FEARM with STALLI lighting | 1931-19?? | used with front lenses 1, 2 or 3, WICAP and WINKO | ||
FGHOO | Replacement hood for Hektor f= 7.3 cm 1:1.9 | 1936-1946 | - | ||
FGOOE | No. 1 light infra-red filter; screw-on type I | ca.1933 | - | ||
FHKOO | Single film holder for I, II, III, IIIa, IIIb1 | 1935-1960 | - | ||
FHOOD | No. 3 dark infra-red filter; screw-on type I | ca.1935 | - | ||
FIAKU | Small ball and socket tripod head; nickel plated until 1936; earliest had dished camera support plate | 1926-19?? | - | ||
FIALT | Holder for film handling during the development process | 1930's | - | ||
FIAMA | Panoramic tripod head for 5 cm lens | 1926-19xx | - | ||
FIARO | Stereoly slide bar 75 mm long | 1926-1926 | - | ||
FIATE | Stereoly slide bar 150 mm long; early version had center tripod bush; later versions with off-center tripod bush | 1926-1940 | - | ||
FIAVI | Angle bracket to support camera on panorama head | 1929-19?? | - | ||
FIBLA | Small canister spirit level for camera top shoe or on FIAVI for vertical pictures; replaced by DOOLU in 1936 | 1929-1935 | - | ||
FIBOB | No. 2 medium infra-red filter; screw-on type G | ca.1933 | - | ||
FIBOS | Leather neck strap with metal snap hooks for cameras with side lugs | 1936-ca.1950 | - | ||
FICAT | No. 1 light yellow filter; screw-on type F | ca.1930 | - | ||
FICFA | Kodachrome type A flash filter; ADFIK 34 mm mount | ca.1949-1950's | - | ||
FICHR | Kodachrome flash filter; slip-on type A36 | ca.1949-1950's | - | ||
FICOM | No. 2 medium yellow filter; screw-on type F | ca.1930 | - | ||
FICOR | Panchromatic green no. 2 filter; slip-on type A36 | ca.1945 | NY item | ||
FICUR | No. 3 dense yellow filter; screw-on type F; | ca.1930 | - | ||
FIDAY | Kodachrome type F filter; screw-on type L | ca.1959- | - | ||
FIDAYMI | Kodachrome type A filter; screw-on type E39 | ca.1949- | NY item | ||
FIDRI | Shutter release cable, 10 feet long | 1931-19?? | - | ||
FIEKT | Polarising filter; swing-out, slip-on type C with clamping screw | ca.1939 | NY item | ||
FIFLO | Kodachrome photo-flood filter; screw-on type L | ca.1949-1950's | NY item | ||
FIFLOMI | Kodachrome photo-flood filter; screw-on type E39 | ca.1949- | NY item | ||
FIGAM | No. 2 medium yellow filter; slip-on type A36 | ca.1931-1950's | - | ||
FIGDA | Panchromatic green no. 2 filter; ADFIK 34 mm mount | ca.1945 | NY item | ||
FIGIL | Graduated Yellow filter; slip-on type C | ca.1931 | - | ||
FIGON | Adaptor for FISUM polarising filter on Contax | 1949-1950's | NY item | ||
FIGRO | No. 1 light yellow filter; slip-on type A36 | ca.1931-1950's | 13005 | ||
FIGUN | No. 1 light yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item | ||
FIHAZ | Kodachrome haze filter; screw-on type L | ca.1949-1950's | NY item | ||
FIHEL | No. 0 very light yellow filter; slip-on type A36 | ca.1933 | 13000 | ||
FIIRL | No. 1 light infra-red filter; ADFIK 34 mm mount | ca.1949-1950's | NY item | ||
FIKAT | Kodachrome type A filter; slip-on type A36 | ca.1949- | NY item | ||
FIKHA | Kodachrome haze filter; ADFIK 34 mm mount | ca.1949-1950's | NY item | ||
FIKLO | Kodachrome photo-flood filter; slip-on type A36 | ca.1949-1950's | NY item | ||
FIKOZ | Kodachrome haze filter; slip-on type A36 | ca.1949-1950's | NY item | ||
FIKUS | Extendable hood for 4 focal lengths: 3.5-13.5; early black & nickel; later black & chrome; NY all chrome version | 1933-1965 | 12530 | ||
FIKYB | No. 2 medium infra-red filter; slip-on type A36 | ca.1933-1950's | - | ||
FILBY | No. 1 light yellow filter; slip-on type A | ca.1926 | - | ||
FILCA | Film cassette originally for Leica I (model A) only; center spool with locking device introduced in 1939; postwar with shiny brown finish | 1925-1954 | - | ||
FILES | Enlarger used with FILUM arm, FEFFU base and column with lenses 2 & 3 | 1931-19?? | - | ||
FILGE | No. 2 medium yellow filter; slip-on type A | ca.1925 | - | ||
FILOY | Enlarger used with FILUM arm, FEFFU base and column with front lenses 2 & 3 | 1931-19?? | - | ||
FILPO | Polarising filter; swing-out, slip-on type A36 with clamping screw | ca.1939 | NY item | ||
FILSO | No. 1 light yellow filter; slip-on type C | ca.1933 | - | ||
FILTU | No. 3 dense yellow filter; slip-on type A | ca.1925-1926 | - | ||
FILUM | Copy arm (camera bracket) used with FEFFU base and column and STALI lighting = FEPRO | 1931-19?? | - | ||
FILXA | No. 3 dense yellow filter; screw-on type I | ca.1933 | - | ||
FILYT | Enlarger or copying device used with FEARM arm, FESSA or FEHUN base and column with front lenses 2 & 3 | 1931-19?? | - | ||
FIMOO | No. 0 very light yellow filter; screw-on type H | ca.1935 | - | ||
FINON | Polarising filter; swing-out, screw-on type E41 with clamping screw | ca.1939-1950's | NY item | ||
FINOT | Shutter release cable, 10 inches long | 1931-19?? | - | ||
FINOW | Shutter release cable, 10 inches long; metal sheathed | 1939-19?? | NY item | ||
FINUS | No. 3 dense yellow filter; screw-on type G | ca.1931 | NY item | ||
FIOKO | UVa filter; screw-on type F | ca.1931 | - | ||
FIOLA | UVa filter; slip-on type A36 | ca.1931 | 13055 | ||
FIOMU | No. 2 medium infra-red filter; slip-on type C | ca.1933 | - | ||
FIONA | Orange filter; ADFIK 34 mm mount | ca.1945-1950's | NY item | ||
FIOOC | No. 1 light yellow filter; screw-on type H | ca.1935 | - | ||
FIOPY | No. 0 very light yellow filter; slip-on type C | ca.1933 | - | ||
FIORE | UVa filter; screw-on type G | ca.1931 | - | ||
FIOSI | UVa filter; slip-on type C | ca.1933 | - | ||
FIOUX | FSEOO Orange filter; slip-on type A36 | ca.1939 | NY item | ||
FIPAN | Panchromatic green no. 1 filter; ADFIK 34 mm mount | ca.1945-1950's | NY item | ||
FIPHO | Kodachrome photoflood filter; ADFIK 34 mm mount | ca.1949-1950's | NY item | ||
FIPLO | No. 2 medium infra-red filter; screw-on type I | ca.1933 | - | ||
FIPOS | Panchromatic green no. 1 filter; slip-on type A36 | ca.1933-1950's | 13015 | ||
FIPPA | No. 2 medium yellow filter; slip-on type C | ca.1933 | - | ||
FIQUX | Orange filter; slip-on type A36 | ca.1939-1950's | NY item | ||
FIRAD | Graduated Yellow filter; slip-on type A36 | ca.1931 | - | ||
FIRCO | Intermediate collar for using a slip-on filter for Compur Leica (model B) | 1931-19?? | - | ||
FIREG | No. 1 light yellow filter; screw-on type I | ca.1933 | - | ||
FIRGI | Intermediate collar for using a slip-on filter in conjunction with supplementary lenses | 1931-19?? | - | ||
FIRHE | No. 1 light yellow filter; screw-on type G | ca.1931 | 13001 | ||
FIRHU | Rear dust cover for screw lenses | 1939-ca.1954 | - | ||
FIRMY | No. 2 medium yellow filter; screw-on type G | ca.1931 | - | ||
FIROL | Adaptor for FILPO polarising filter on Rolleiflex or Rolleicord | 1949-1950's | NY item | ||
FIRYX | Panchromatic green no. 1 filter; screw-on type I | ca.1933 | - | ||
FISAP | Panchromatic green no. 1 filter; slip-on type C | ca.1933 | - | ||
FISEX | Shutter release cable, 20 feet long | 1931-19?? | - | ||
FISKF | Kodachrome skylight filter; slip-on A36 mount | ca.1954- | NY item | ||
FISON | Hood for 5 cm ELMAR; black cylinder with rectangular aperture until 1933 when changed to round aperture; last version was chrome with set screw | 1925-1963 | 12510 | ||
FISUM | Polarising filter; swing-out, screw-on type L with clamping screw | ca.1939 | NY item | ||
FISUMMI | Polarising filter; swing-out, screw-on type E39 with clamping screw | ca.1939 | NY item | ||
FITAF | Kodachrome type A filter; ADFIK 34 mm mount | ca.1949- | NY item | ||
FITWO | No. 2 yellow filter; ADFIK 34 mm mount | ca.1945-1950's | NY item | ||
FIUNS | No. 0 very light yellow filter; slip-on type A | ca.1933 | - | ||
FIVPL | Complete unit for surgical operation photography with cast iron base and rack and pinion movement | 1939-19?? | |||
FIWAS | No. 0 very light yellow filter; screw-on type I | ca.1933 | - | ||
FIWET | UVa filter; screw-on type I | ca.1933 | - | ||
FIWIG | No. 2 medium yellow filter; screw-on type I | ca.1933 | - | ||
FIXIO | Panchromatic green no. 1 filter; screw-on type G | ca.1933 | - | ||
FIXTA | No. 0 very light yellow filter; screw-on type G | ca.1933 | - | ||
FKDELM | Kodachrome type F filter; slip-on type A36 | ca.1959- | - | ||
FKDSAX | Kodachrome type F filter; screw-on type E58 | ca.1959- | - | ||
FKDSMI | Kodachrome type F filter; screw-on type E39 | ca.1959- | - | ||
FKDSMT | Kodachrome type F filter; screw-on type E41 | ca.1959- | - | ||
FKDTEL | Kodachrome type F filter; screw-on type E48 | ca.1959- | - | ||
FLASH | Horizontal mounted flash unit (like SYNCO) for Standard Leica (model E) | ca.1938 | - | ||
FLECT | Dull surfaced flash reflector for portraits | ca.1938 | - | ||
FLOOA | UV light copying device with ELMAR | 1939-19xx | - | ||
FLOTH | Plumbbob for copy stand use with U-shaped or angular harness for ELMAR; FLOTH + STARE = STAOT copy stand | 1931-19?? | - | ||
FLQOO | Hood for 35 mm Elmar; black or chrome; superseded by FOOKH | 1936-1950 | also NY version | ||
FMOOZ | No. 1 light infra-red filter; slip-on type C | ca.1933 | - | ||
FMSOO | No. 3 dark infra-red filter; slip-on type C | ca.1935 | - | ||
FNOOY | No. 1 light infra-red filter; screw-on type H | ca.1935 | - | ||
FNUOO | No. 3 dark infra-red filter; screw-on type H | ca.1935 | - | ||
FOCOMAT | Enlarging device used with Visoflex II & III | 1963-19?? | - | ||
FODIS | Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions | 1925-1929 | 2.15 cm wheel | ||
FODUA | Longbase rangefinder (without leather case) to measure distance from film plane to object; metric and international versions | 1925-1929 | 2.15 cm wheel | ||
FOFER | Longbase rangefinder with leather case to measure distance from film plane to object; metric and international versions with fixing clip; Nagel version has N on the wheel | 1925-1939 | 3.5 cm wheel | ||
FOKAL | Hinged bracket for attaching FOKIN to camera | 19xx-19xx | - | ||
FOKIN | Longbase rangefinder for cine cameras | 1926-1940 | 3.5 cm wheel | ||
FOKOS | Short black & nickel, black & chrome or all chrome rangefinder with 7.5 cm base; after 1949 - chrome only version with 6.2 cm base | 1933-1966 | - | ||
FOKUX | Ball and socket joint for longbase rangefinder | 19??-1940 | - | ||
FONOR | Longbase rangefinder for 6x9 to 10x15 cm; metric and international versions | 19??-1940 | - | ||
FONOT | Shutter release cable, 10 inches long with set screw | 1955-19?? | 14067 | ||
FOOBD | Graduated Green filter; slip-on type A36 | ca.1938 | - | ||
FOOCR | Graduated Green filter; slip-on type C | ca.1938 | - | ||
FOOKH | Hood for 3.5 cm Summaron & Elmar | 1951-1966 | 12505 | ||
FOOMI | Short, chrome ball and socket tripod head | 1938-1960 | 14104 (3/8") and 14105 | ||
FOONW | FARUX Scale ring for Hektor 2.8 cm | ca.1936 | |||
FOOQL | FARUX Scale ring for Telyt 20 cm | ca.1936 | |||
FOOVA | Tank for loading film cassettes in daylight | 1939-1950's | - | ||
FOOXB | Filter holder; slip-on type A36 | ca.1951 | 13365 | ||
FOOXC | Filter holder; screw-on type L | ca.1951 | - | ||
FOOXD | Filter holder; screw-on type E41 | ca.1951 | 13375 | ||
FOOXE | Filter holder; screw-on type E58 | ca.1951 | 13380 | ||
FOOXF | Filter holder; screw-on type E48 | ca.1951 | 13385 | ||
FOOXH | Filter holder; screw-on type E39 | ca.1955 | 13371 | ||
FOOXK | Filter holder; screw-on type E43 | ca.1959 | 13384 | ||
FOREST | 1927-1939 | 6 x 42 - CF | 7.1 deg 122 yd / 1000 yd |
28 oz | $80 in 1929 |
FORESTON | 1927-1939 | 6 x 42 | 7.1 deg | also monocular MONOFOREST; 735 gm / 26 oz | |
FORESTONA | 1927-1939 | 8 x 42 | 6.3 deg | 735 gm / 26 oz | also monocular MONOFORSTA; |
FORSTA | 1927-1939 | 8 x 42 - CF | 6.3 deg 110 yd / 1000 yd |
20 oz (28 oz. 1929) | $85 in 1929 |
FOSAR | Angular bracket for holding ground glass housing VEHIG | ca.1933 | - | ||
FPKELM | Kodachrome type FP filter; slip-on type A36 | ca.1959- | - | ||
FPKSAX | Kodachrome type FP filter; screw-on type E58 | ca.1959- | - | ||
FPKSMI | Kodachrome type FP filter; screw-on type E39 | ca.1959- | - | ||
FPKSMT | Kodachrome type FP filter; screw-on type E41 | ca.1959- | - | ||
FPLTEL | Kodachrome type FP filter; screw-on type E48 | ca.1959- | - | ||
FPOOW | Orange filter; screw-on type G | ca.1939 | - | ||
FQOOV | Orange filter; screw-on type H | ca.1939 | - | ||
FRCOO | Orange filter; screw-on type I | ca.1939 | - | ||
FSEOO | Orange filter; slip-on type C | ca.1939-1950 | - | ||
FTGOO | Orange filter; slip-on type A36 | ca.1939 | 13025 | ||
FUECD | Complete extension tube set for FULDY; also for OORES | 1936-1939 | - | ||
FUFIF | 15 mm extension tube for FULDY | 1936-1939 | NY item | ||
FUFOR | 45 mm extension tube for FULDY | 1936-1939 | NY item | ||
FULDY | Sliding focusing stage using Leica screw thread to hold camera (later know as "Focoslide") in 4 types for various screw-thread cameras to sn. 400000; superseded by FULEC | 1930-1951 | - | ||
FULEC | Sliding focusing stage using Leica screw thread to hold camera for screw-thread cameras after sn. 400000 | 1948-1951 | - | ||
FULET | Like FULDY without sliding camera attachment | ca.1939 | NY item | ||
FULFO | 30 mm extension tube for FULDY | 1936-1950's | NY item | ||
FULGX | 60 mm extension tube for FULDY | 1936-1950's | NY item | ||
FULHI | 90 mm extension tube for FULDY | 1936-1950's | NY item | ||
FULOR | 12 mm extension tube for FULDY | 1936-1939 | NY item | ||
FUSEV | 7 mm extension tube for FULDY | 1936-1939 | NY item | ||
FVOOQ | 15 mm extension tube for ZWTOO-HESUM Summar focusing mount | ca.1949-1950's | - |
