M
| Leica Code | Description | Production Year | Remarks | ||
| MAALK | Micro / macro stand, complete | ? | - | ||
| MAARP | Leicameter-M, with a selenium booster cell | ? | - | ||
| MACCA | Leicameter-M, with a selenium booster cell | ca.1931 | - | ||
| MADHA | Micro / macro stand with holder for Leica with micro Visoflex, etc. . | 19??-19?? | - | ||
| MAKAM | Leicameter-M, with a selenium cell | ca.1958 | - | ||
| MADAX | Leicameter-M, with a selenium cell for 9x12cm | 1937 | - | ||
| BILOM | 1930-ca.1935 | 8 x 30 | 6.3 deg | - | |
| BILOMIT | 1930-ca.1935 | 8 x 30 – CF | 8.5 deg | - | |
| BIMAX | ca.1930-1935 | 8 x 24 | 8.5 deg | - | |
| BIMAXIT | ca.1930-1935 | 8 x 24 – CF | 8.5 deg | - | |
| AVIOSEPTIT | 1930-1931 | 7 x 50 - CF | 7.3 deg | - | |
| AVIODIXIT | 1931 | 10 x 50 - CF | 5 deg | - | |
| AVIONAR | ? | 15 x 60 | - | ||
| CAMPAR | 1932-1959 | 10 x 40 | 7.3 deg | 29 oz | - |
| CAMPARIT | 1932-1959 | 10 x 40 – CF | 7.3 deg | 30 oz | - |
| CAMPOFORT | 1932-1962 | 15 x 60 – IF | 4.6 deg | 44 oz | - |
| CAMPOFORTIT | 1932-1962 | 15 x 60 – CF | 4.6 deg | 45 oz | - |
| CAMPOMAR | 1932-1949+ | 12 x 50 | 5.7 deg | - | |
| CAMPOMARIT | 1932-1949+ | 12 x 50 – CF | 5.7 deg | - | |
| MARSEPT | 1932-1962 | 7 x 50 | 7.3 deg 128 yd / 1000 yd |
33 oz, $156 1954. $225 1961. (1950s FIBAR, 1960s 40110) also monocular MONMAR (FEAFA - 41010) | |
| MARSEPTIT 1950s FITGE 1960s 40025 |
1932-1962 | 7 x 50 - CF | 7.3 deg | 960 gm 34 ozm $162 1954. $235 1961 | |
| MARDIX 1950s FIBLO 1960s 40125 |
1932-1962 | 10 x 50 | 5 deg 87 yd / 1000 yd |
33.5 oz, $165 1954. also monocular MONDIX (FEALF 41030) | |
| MARDIXIT 1950s FITME 1960s 40040 |
1932-1962 | 10 x 50 - CF | 5 deg | 940 gm 33.5 oz, $171 1954. $225 1961. | |
| MAROCTO 1950s FIBEF 1960s 40115 |
1932-1962 | 8 x 60 | 6 deg 107 m / 1000 m |
1220 gm 43 oz, $186 1954, $230 1961 also monocular MONOCHT FEAHU 41020 | |
| MAROCTIT 1950s FITID 1960s 40030 |
1932-1962 | 8 x 60 - CF | 6 deg | 1250 gm 44 oz, $192 1954, $250 1961 | |
| MARDOCE 1950s FIBOS 1960s 40135 |
ca.1939-1962 | 12 x 60 | 4.3 deg 75 yd / 1000 yd |
42.5 oz, also monocular MONDUCE, FEARA, 41040 | |
| MARDOCIT 1950s FITSO 1960s 40050 |
ca.1939-1962 | 12 x 60 - CF | 4.3 deg | 1225 gm 43 oz, $195 1954, $245 1961 | |
| MBOOC | Selenium cell for Leicameter-MC | 1958-19?? | - | ||
| MBOOW | Selenium cell for Leicameter for METRA | 1955-19?? | - | ||
| MBOOW-C | Selenium booster cell for Leicameter-MC | 1951-19?? | |||
| MBOOWT | Selenium booster cell for Leicameter 2 | 1951-19?? | - | ||
| MBROO | Water-resistant metal case for all models up to Leica IIIf | 19??-1953 | - | ||
| METER | Leicameter NY version, similar to Metrawatt MF/LC 60 | 1951 | - | ||
| METNBC | METWMT + MBOOWT | 1954 | NY item | ||
| METNBD | METWMT + MBOOWT | 1956-1957 | NY item | ||
| METMBG | METWMT + MBOOWT, with an expanded ASA-scale | ? | NY item | ||
| METRA | Leicameter-M, with a selenium booster cell | 1955-19?? | 14200 | ||
| METRPC | Carrying chain with bracket for METNBC and METWMT | ? | - | ||
| METTNC | Leicameter Model 3, NY version | 1956 | - | ||
| METWMT | Leicameter Model 2, NY version | 1954 | - | ||
| MIBAC | For MIKAS, ½ x reducer lens | 1950 | - | ||
| MIBAC-M | For MIKAS, ½ x reducer lens with bayonet | 1958-1959 | - | ||
| MICCA | Micro camera equipment with MACCA, 4.5 x 6 cm format | 1923-1924 | - | ||
| MICCO | M3 sync connector for CHICO flash | ? | 15524 | ||
| MICCS | Like MICCO for external flash units with the same connection | ? | - | ||
| MICCX | M3 sync connector for CHICO flash, longer version | 1956 | - | ||
| MICCZ | M3 sync connector for CHICO flash, more stable version | 1958 | - | ||
| MIDAP | Conical adapter for MIKAS | 1930's | - | ||
| MIFCA | Micro 1/3x attachment with shutter for connecting to microscope body MIFILMCA | 1926-1933 | - | ||
| MIFOANSA | Back for MIFCA, CAFOT, etc. | ? | - | ||
| MIKAS | Micro attachment with lateral focusing for connecting screw Leica to a microscope | 1933-1950s | - | ||
| MIKAS-M | Micro attachment with lateral focusing for connecting bayonet Leica to microscope | 1959-19?? | - | ||
| MIOOP | Camera Adapter for Microscope | 1938 | - | ||
| MIOOT | Camera Adapter for Microscope | 1951-1952 | - | ||
| MONLA | Microscope lamp | 1933-19?? | - | ||
| MOOBG | Microscope extension tube M-1:2, 16 mm | 1936-19?? | - | ||
| MOODH | Microscope extension tube M-1:1.5, 24.5mm | 1936-19?? | - | ||
| MOOGW | Microscope extension tube M1:1, 41mm | 1936-19?? | - | ||
| MOOLY | Spring driven "Leica-Motor" 1st version for Leica IIIa (model G) and Leica IIIb | 1938 | - | ||
| MOOLY-C | Spring driven "Leica-Motor" 2nd version for Leica IIIc and Leica IIId | 1940-1949 | less than 200 manufactured | ||
| MOONZ | M3 sync connector for CEYOO flash | 19??-19?? | 15521 | ||
| MOOSP | Close focus tube for Telyt 20 and 40 cm lenses; 45 mm diam.; chrome or black | 1935-19?? | 14020 |
