APO-Elmar-S 180mm f/3.5
- Order numbers - 11071 - 11053 (CS version with Central Shutter)
- Production era - 2009- (CS Oct 2012)
- Lenses /groups - 9 /7
- Optical design - Internal focusing
- Image angle (diagonal, horizontal, vertical) - approx. 17°, 14°, 9.5°, approx. corresponds to 144 mm in 35 mm-format
- Aperture range - 3.5 to 22
- Shortest distance - 1.5 m - (1.1 m w/ Close-Up Converter Lens 16032)
- Largest image scale - 1:7 - (1.45 w/ Close-Up Converter Lens 16032)
- Filter thread size - 72 mm
- Dimensions (diameter/length) - 88 mm/151 mm
- Weight: 1150 g (CS: 1300 g )
- Accessories included - Lens Hood : 12403 - Rear lens cover : 16020 - Lens cover S : 16018
- Accessories optional - 16032 - Elpro-S 180 mm (introduced November 2012) reduces the minimum focus distance of the 180mm lens to 3.6' (1.1 m) and increases the maximum reproduction ratio of the lens from 1:7 to 1:4.5.
- Leica Tech Data - APO-Elmar-S 180mm f/3.5.pdf - courtesy Summilux.net
Leica APO-Elmar-S 180mm f/3.5 Serial Numbers
Serial numbers compiled from known TS-APO-Elmar-S 120mm f/5.6 ASPH. lenses| SN Start | SN End | Product | Year | Total |
| ~4090070 | 4114350- | APO-Elmar-S 180mm f/3.5 | 2009-2011 | 24,281+ |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2009-Current | unknown |
