Elmar (III) 1:4 / 90mm
- Leica Order No. - ELANG 11 730 (S), ELANG-M 11 830 (M) LLC - 168
- Production era - 1964-1965 < 9,400 lenses with < 500 in screw-mount (per Westlicht)
- Variants -
- Number of lenses /groups - 3 /3
- F stop range - f/4-f/32
- Smallest object field -
- Diaphragm setting /type -
- Filter type -
- Accessories - Hood: IUFOO 12575
- Materials - Clear anodized aluminum
- Weight - 300 g /10.58 lb
- Inscription - Leitz Wetzlar 169XXXX Elmar f=9cm 1:4 or some with Ernst Leitz GmbH Wetzlar
Elmar (III) f= 9 cm 1:4 Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf| SN Start | SN End | Product | Year | Total |
| 1913001 | 1914000 | Elmar 90 mm 1:40 (S+M) | 1962 | 1000 |
| 1920001 | 1921000 | Elmar 90 mm 1:40 (S+M) | 1962 | 1000 |
| 1936001 | 1937000 | Elmar 90 mm 1:40 (S+M) | 1962 | 1000 |
| 2088801 | 2090800 | Elmar 90 mm 1:40 (M) | 1965 | 2000 |
| 2097501 | 2097900 | Elmar 90 mm 1:40 (M) | 1965 | 400 |
| 2123651 | 2125650 | Elmar 90 mm 1:40 (S+M) | 1965 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1964-1965 | 9,400 |
