TS-APO-Elmar-S 120mm f/5.6 ASPH.
- Order number - 11079
- Production era - 2012-
- Optical design
- Lenses /groups - 6 /4
- Image angle (diagonal, horizontal, vertical) - 23.6°, 20°, 13.6°, corresponds to approx. 96 mm focal length in 35 mm format
- Position of entrance pupil - 65.6 mm
- Setting /function - Electronically controlled diaphragm, set using dial on camera, including half values
- Aperture range - 5.6 to 32
- Focusing range - 0.95 m to infinity
- Distance setting
- Smallest object field - 159 mm × 239 mm
- Largest reproduction ratio - 1 : 5.3
- Size
- Filter mount - Internal thread for E95 filter, filter mount does not rotate
- Dimensions (diameter /length) - 108 mm /144 mm
- Weight: 1110 g
- Leica Tech Data - TS-APO-Elmar-S 120mm f/5.6 ASPH.pdf
Leica TS-APO-Elmar-S 120mm f/5.6 ASPH. Serial Numbers
Serial numbers compiled from known TS-APO-Elmar-S 120mm f/5.6 ASPH. lenses~ stolen lens, please report if found on sale
| ~4189867 | unknown- | TS-APO-Elmar-S 120mm f/5.6 ASPH. | 2012 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 2012-Current | unknown |
