GHIJ
Revision as of 16:55, 17 September 2009 by Admin (talk | contribs)
GBOOM No. 0 very light yellow filter; screw-on type L ca.1939 -
GBWOO No. 1 light yellow filter; screw-on type L ca.1939 -
GCHEO Kodachrome flash filter; screw-on type L ca.1949-1950's NY item
GCHEOMI Kodachrome flash filter; screw-on type E39 ca.1949-1950's NY item
GCOOL No. 2 yellow filter; screw-on type L ca.1939 -
GCSKYMI Kodachrome skylight filter; screw-on type L ca.1949-1950's NY item
GCYOD Panchromatic no. 2 green filter; screw-on type L ca.1939 -
GCYOO Panchromatic no. 1 green filter; screw-on type L ca.1939 -
GDOOK Orange filter; screw-on type L ca.1939 -
GECOO Infra-red no. 1 light filter; screw-on type L ca.1939 -
GFEOO Infra-red no. 2 medium filter; screw-on type L ca.1939 -
GFOOH Infra-red no. 3 dark filter; screw-on type L ca.1939 -
GHIOO UVa filter; screw-on type L ca.1939 -
GHOOF Graduated yellow filter; screw-on type L ca.1939 -
GIIBR Microphotography 18 inch cable release for MIKAS with set screw mount 1939-1950's -
GIIEF Microphotography 1/3x conical extension tube for MIKAS with screw-mount 1939-1950's -
GIIEF-M Microphotography 1/3x conical extension tube for MIKAS with M-mount 1939-1950's -
GIIFT Microphotography 18 inch cable release for MIKAS with screw-mount 1939-1950's -
GIIMW Microphotography 1/2x conical extension tube for MIKAS with screw-mount 1939-1950's -
Microphotography 1/2x conical extension tube for MIKAS with M-mount 1956-1960's -
GIINK Microphotography 1x conical extension tube for MIKAS with screw-mount 1939-1950's -
GIIOX Single exposure housing without shutter 1939-1940's NY item
GILOO Graduated green filter; screw-on type L ca.1939 -
GOOEF Leica IIIg body 1957-1970 -
GOOEL Leica IIIg with Elmar f= 5 cm 1:2.8 (ELMOO) 1957-1970 -
GOOMI Leica IIIg with Summicron (I) f= 5 cm 1:2 (SOOIC) 1957-1970 -
GOORM Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES or 250 stage GRBOO 1938-ca.1950 -
GOOSZ Complete copy stand with GOOZQ arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head 1938-ca.1950 -
GOOZQ Copy stand arm for 1 1/4 inch column with tape measure for rotating stage OORES either direct or with ball and socket KAGOON head 1938-1950 -
GRBOO Sliding stage for Leica 250 (models DD, FF & GG) 1935-ca.1950 -
GROOW Basic copy stand with spring mounted base plate 19xx-19xx -
GVKOO 30 mm extension ring G for ZWTOO-HESUM 19xx-19xx -
HEBOO Slow speed shutter release for 1, 1/2, 1/4, 1/8 s in nickel or later chrome 1935-1969 -
HEFAM Hektor f= 13.5 cm 1:4.5 black M-mount 1954-1960 -
HEFAM-CHROM Hektor f= 13.5 cm 1:4.5 chrome M-mount 1954-1960 -
HEFAM-KUP ? 19xx-19xx -
HEFAR Hektor f= 13.5 cm 1:4.5 chrome 1933-1959 -
HEGRA Hektor f= 7.3 cm 1:1.9 black lacquer & chrome 1934-1946 -
HEKON Hektor f= 7.3 cm 1:1.9 black lacquer & nickel 1931-1933 -
HEKTO Hektor f= 5 cm 1:2.5 nickel or chrome 1930-1936 -
HEPET Close-up supplementary front lens no. 3 for Hektor 5 cm 1928-1950's -
HEPIK Close-up supplementary front lens no. 2 for Hektor 5 cm 1928-1950's -
HEPRO Close-up supplementary front lens no. 1 for Hektor 5 cm 1928-1950's -
HFOOK Short-base clip-on rangefinder for Leica models A, B & C 1920's-ca.1936 -
HGOOI Rear cover for 125 mm Hektor 1930's-1960's 14053
HIIBE Stand for photographing small objects; with adjusment by rack and pinion; with rotation and tilt 1939-1940's -
HIKOU ?Hector 2.5/12.5cm? 19xx-19xx -
HKMOO ? 19xx-19xx -
HMOOD ? 19xx-19xx -
HOOAR Yellow no. 0 very light filter; screw-on type E39 ca.1955 13081
HOOBE Yellow no. 1 light filter; screw-on type E39 ca.1955 13086
HOOCS Infra-red no. 1 light filter; screw-on type E39 ca.1955 -
HOODF Infra-red no. 2 medium filter; screw-on type E39 ca.1955 -
HOOET Infra-red no. 3 dark filter; screw-on type E39 ca.1955 -
HOOFG Panchromatic filter; screw-on type E39 ca.1955 -
HOOGU Orange filter; screw-on type E39 ca.1955 -
HOOIV UVa filter; screw-on type E39 ca.1955 -
HOOKI Blue filter; screw-on type E39 ca.1955 13098
HOOPY Hektor f= 2.8 cm 1:6.3 nickel 1935-1936 -
HOOPY-CHROM Hektor f= 2.8 cm 1:6.3 chrome 1936-1955 -
IASUU ? 19xx-19xx -
IBSOR ? 19xx-19xx -
IDCOO M3 leather ready case 19xx-19xx -
IFLEX ? 19xx-19xx -
IFSTA ? 19xx-19xx -
IGEMO M3 body 19xx-19xx -
ILNOO Elmar (II) f= 9 cm 1:4 collapsible 19xx-19xx -
ILNOO-M 90mm f/4 Elmar collapsible M-mount 1954-1968 -
ILLUM ? 19xx-19xx -
ILNUU ? 19xx-19xx -
IMARO M3 with F = 5 cm 1:3.5 Elmar 19xx-19xx -
IMFIN ? 19xx-19xx -
IMPUU ? 19xx-19xx -
IMPUU-IZOUU ? 19xx-19xx -
IROOA ? 19xx-19xx -
IRZOO ? 19xx-19xx -
IRZUU ? 19xx-19xx -
ISAIO M3 with F = 5 cm 1:1.5 Summarit 19xx-19xx -
ISBOO ? 19xx-19xx -
ISBUU ? 19xx-19xx -
ISOOZ ? 19xx-19xx -
ISUMO M3 with F = 5 cm 1:2 Summicron II 19xx-19xx -
ITDOO ? 19xx-19xx -
ITOOY ? 19xx-19xx -
IUFOO ? 19xx-19xx -
IUOOP MP and MP2 1956-1959 -
IVZOO ? 19xx-19xx -
IWKOO ? 19xx-19xx -
IXMOO ? 19xx-19xx -
IZQOO ? 19xx-19xx -
