V
| VACUB | Earliest Leica flash unit | ca.1933 | NY item |
| VALOY | Complete copy stand type I and II OKYNO | 19??-19?? | - |
| VAMAX | X-ray enlarger used with VEHAL and 48" VESTA arm | 1933-19?? | - |
| VARIP | Large copying device with VELTU base and column, and VEARM arm and STAFO lighting, VEHIG and STAMA | 1933-19?? | - |
| VEARM | Large copying device with 40" VELTO base and column, front lenses 1, 2 & 3 and VALFA or FILYT enlarger | 1933-19?? | - |
| VEDUK | Cable with plug and switch for VEKAS | 1931-19?? | - |
| VEHAL | Bent camera arm with wingnut; used with VERAP | 1931-19?? | - |
| VEHIG | Fixed focusing stage with ground glass housing complete with 5x magnifier and protecting lid for camera body opening | 1933-19?? | - |
| VEKAS | 16 x 20 inch lightbox with 6 lights, VEDUK cable and various glass covers to hold film flat; on base of VERAP | 1931-19?? | - |
| VEKOT | 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and VERYK glass covers to hold film flat | 1931-19?? | - |
| VELIF | Arm for VIHAK small copy stand | 1933-19?? | - |
| VELTU | Base and column part of VARIP or ROOKA large copy stand | 1933-1936 | - |
| VELYP | 16 x 12 inch glass covers to hold film flat | 1933-19?? | - |
| VEPUT | 16 x 12 inch lightbox with 4 lights, VEDUK cable and various glass covers, VELYP to hold film flat | 1932-19?? | - |
| VERAP | X-ray reproduction device with VESTA base and column, VEHAL arm and VEKAS light box with VEHIG and 12 feet of cable with switch | 1931-19?? | - |
| VERYK | 7 1/4 x 5 1/4 inch lightbox with 4 lights, VEDUK cable and various glass covers, VEYRK to hold film flat; on base of VERAP | 1932-19?? | - |
| VESTA | Base and column; used with VERAP | 1931-19?? | - |
| VEZUK | Curved lateral holder to support the camera when used vertically | ca.1933 | - |
| VIDEO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 10.5cm lenses | 1932-1933 | black |
| VIDOM | Universal viewfinder for the focal lengths 3.5-13.5 cm with non-zoom, mirror-image | 1933-1939 | |
| VIEFF | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIEME | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 13.5cm lenses | 1932-1933 | black |
| VIFUR | Small, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1933-1936 | black or chrome |
| VIGEH | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm lenses | 1932-1933 | black |
| VIHAK | 74 | 19??-19?? | - |
| VIHEU | Small, torpedo shaped finder for 3.5cm, 5cm lenses | 1932- | black |
| VIKAN | Small, torpedo shaped finder for 3.5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIKUL | 9 1/2 x 12 inch lightbox with 3 lights and various glass covers, VIRUP to hold film flat | 1933-19?? | - |
| VILLO | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VIOAD | 12 | 19??-19?? | - |
| VIOOH | Universal viewfinder (12015) for the focal lengths 3.5-13.5 cm | 1940-1964 | reaches 2.8 cm with TUVOO add-on |
| VISAX | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1932-1933 | black |
| VISET | Small, torpedo shaped finder for 3.5cm, 9cm, 13.5cm lenses | 1932-1933 | black |
| VISIL | 10 | 19??-19?? | - |
| VISOR | The first, torpedo shaped finder for 3.5cm, 5cm, 13.5cm lenses | 1931-1931 | black |
| VISSI | Small, torpedo shaped finder for 3.5cm, 9cm lenses | 1932-1933 | black |
| VITRE | Small, torpedo shaped finder for 3.5cm, 5cm, 10.5cm lenses | 1933-1936 | black or chrome |
| VIUNA | Small, torpedo shaped finder for 3.5cm, 5cm, 7.3cm lenses | 1933-1936 | black or chrome |
| VIZWO | Small, torpedo shaped finder for 3.5cm, 5cm, 9cm lenses | 1933-1936 | black or chrome |
| VLOOF | Spare, folding reflector for CEYOO, CEYAL or CAVOO | 1951-1953 | 15532 |
| VMCOO | Intermediate ring for use of Elmar front lenses on 5 cm Summar | 19??-19?? | - |
| VOOLA | Thin metal diaphram setting ring to adjust aperature of 5 cm Elmar when slip-on filter is in place | 1955-19?? | 16621 |
| VOOQF | 32 inch copy stAND column with guide rail like Valoy II OVURO | ca.1955 | 17552 |
| VORGI | Intermediate ring for use of Hektor front lenses on 5 cm Summar | 19??-19?? | - |
| VOROD | Sereoly system for Leica II, III and IIIa | 1932 | NY item |
| VORSA | Early Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa | 1931-1939 | - |
| VORSTAN | Sereoly system for non-rangefinder cameras | 1933-1934 | - |
| VORUF | Stereoly arm to mount prisum on Leica II, III and IIIa | ca.1939 | - |
| VOSTN | Sereoly system for non-rangefinder cameras and later for Leica II, III and IIIa | 1935-1939 | - |
| VOTIV | Stand for VOTRA stereo transparency viewer; nickel plated | 1931-19?? | - |
| VOTRA | Stereo transparency viewer; nickel plated | 1931-19?? | - |
| VSPOO | Focusing mount for Focoslide OOBAZ or OTGOO using F = 5 cm 1:2 Summicron II | 1956-1968 | 16608 |
| VTOOX | Aperature setting ring for 50mm f/2.8 Elmar-M | 1958-19?? | 16622 |
| VTROO | Aperature setting ring for 60 mm f/2.2 Summicron-M | 1956-19?? | 16686 |
| VUROO | Valloy II copy stand with 25 1/2 inch column including UWOOS bracket to take FOCOSLIDE | 1960-19?? | 16702 16704-3/8" bush |
| VWOOU | Repro N extension tub 26mm fitted between Focoslide OOBAZ or OTGOO | 1956-19?? | 16689 |
| VXOOT | Focusing mount for Focoslide OOBAZ using F = 5 cm 1:3.5 Elmar and VALOO aperature setting ring | 1958-19?? | 16622 |
| VXZOO | Focusing mount for Focoslide OOBAZ or OTGOO using 50mm f/2.8 Elmar-M | 1958-19?? | 16608 |
